Gear lever - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Gear lever (/showthread.php?tid=76008) |
Gear lever - Dustydes - 01-07-16 Hi all Searched google with no luck. How much free play should there be in gear lever. Mine moves up about an inch of freeplay before I can then move up more to select gear. It makes it hard to adjust for boot as I ride with toes on the pegs then slide foot forward to up shift. I need the gap to slide boot in but then there is a lot of movement to select gear. If I reduce gap its hard to get boot to slide in nicely and I still have the same amount of free play. Has the spring gone weak? does it hold lever in up position? I have seen the R1 mod but is mine normal at moment ? Des Re: Gear lever - stevegixer - 01-07-16 R1 mod ? Re: Gear lever - Dustydes - 02-07-16 (01-07-16, 11:04 PM)stevegixer link Wrote: R1 mod ? R1 has shorter shift linkage, less lift to select gears Might have found the answer here, away on holiday today so cant check for a week or so http://www.yamahafz1oa.com/forum/showthread.php?p=2425924 |
