fork component interchangeability?! - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: fork component interchangeability?! (/showthread.php?tid=75950) |
fork component interchangeability?! - Bretty - 22-06-16 My front fork has developed a bit or a knock or play, it's hard to describe. Anyway, I've picked up another set of forks to switch them over. The knackered set on my bike have preload adjusters The older pair I've just got don't have preload adjusters (older?). Is it possible to swap the preload adjusters over to the good fork? Or are a lot of the internals different? Thank you, Brett Re: fork component interchangeability?! - darrsi - 22-06-16 You can swap them over, but I had a similar scenario and bought older forks without adjusters, and didn't feel the need to do it. Had no issues whatsoever, as the adjusters were always turned right in at the firmest point anyway, anything other than that and I felt they were pretty useless. 15w oil, instead of 10w, is what made all the difference, that's a must. Re: fork component interchangeability?! - Bretty - 22-06-16 Cheers Darrsi! Re: fork component interchangeability?! - Punkstig - 23-06-16 Is it definitely the forks you're getting a knock from and not either the head race bearings being knackered or even the brake pads moving in the calipers!? (two easy things to check) |
