Creaking folks - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Creaking folks (/showthread.php?tid=75786) |
Creaking folks - Bonzodave - 30-05-16 Hi all I think I already know the answer to this question but here goes my folks are creaking with a deferent bump at the bottom when I rock back and forth with the front brake on, does this mean they are knackered? Re: Creaking folks - bandit - 30-05-16 Don't knock us old folks,you will be old one day! [img alt=LOL]http://foc-u.co.uk/Smileys/efocicon/lol.gif[/img] Are you sure it's the forks & not the front brake pads knocking in the calipers,put the front tyre up against a wall & then try the forks with brakes off. Re: Creaking folks - Bonzodave - 30-05-16 Cheers I'll check Re: Creaking folks - darrsi - 30-05-16 Ill fitting pads can cause a knock, as can the outside part of a floating brake disc. If it's a heavy knock that you can feel in the handlebars then it might need a little tightening at the top end. (steering head) |
