Tap & Bolt Size - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Tap & Bolt Size (/showthread.php?tid=75779) |
Tap & Bolt Size - old son - 29-05-16 Can somebody remind me what size tap and what size Allen bolts I need to remove the AIS from above the exhaust pipes at the front of the engine. Thanks Re: Tap & Bolt Size - Cellarman - 29-05-16 M8 tap & socket-cap bolts use a non tapered tap with plenty of lube Follow Pat's guide here & you wont go wrong Re: Tap & Bolt Size - old son - 29-05-16 (29-05-16, 05:03 PM)Cellarman link Wrote: M8 tap & socket-cap bolts use a non tapered tap with plenty of lube Thanks. How long do the bolts need to be? Re: Tap & Bolt Size - Falcon 269 - 29-05-16 Sorry to contradict but I strongly recommend an HSS tapered tap to cut the thread in the stubs. You need to cut the thread to about 1cm depth only, so a tapered tap will give you all you need and more with much less chance of snagging while you're cutting the thread.
Re: Tap & Bolt Size - old son - 29-05-16 Thanks Mike Re: Tap & Bolt Size - Cellarman - 29-05-16 Sorry about that I meant to say tapered (brain fade) :lol I used 8mm stainless ones from Ebay cost a couple of quid Re: Tap & Bolt Size - Falcon 269 - 29-05-16 Brain fade? Yup, get that all the time
Re: Tap & Bolt Size - old son - 29-05-16 Ive just bought five from eBay for 99p!!! Prices must becoming down ha ha Re: Tap & Bolt Size - old son - 29-05-16 Do I need an M8 x 1.0, 1.25 or 1.5 tap? Tap & Bolt Size - mickvp - 29-05-16 Iirc 1.25 is standard M8 pitch, but it doesn't matter really as long as you get the right pitch bolts to match
Re: Tap & Bolt Size - old son - 29-05-16 Thanks. Re: Tap & Bolt Size - RMT1983 - 29-05-16 ive got a set from Ivan that I wont be using............................ pm me if your interested mate Re: Tap & Bolt Size - old son - 29-05-16 I've ordered the bolts and tap from eBay now. Sorry Re: Tap & Bolt Size - mick chiz - 09-06-16 id try running a 6.8mm drill down 1st.its the right size for tapping m8x1.25 holes |
