ignition key - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: ignition key (/showthread.php?tid=75749) |
ignition key - Dustydes - 25-05-16 My ignition lock was a little bit awkward to operate, so a little bit of wd40 I thought would do the trick. Now it's even harder and I have to wriggle the key to get it to turn. Do I just get a new key cut? Des Re: ignition key - RMT1983 - 25-05-16 wd-40 is no good!!! it would have stripped all the grease out of it and left it bare!!! hence the reason people use it to clean oil/crap off stuff!!! I'd get a tin of white lithium grease and try that before anything else! I use it every 3/4 months on my locks and it works well! Re: ignition key - Dustydes - 25-05-16 Thanks RTM1983 Will try that first Des Re: ignition key - Ben Diesel - 28-05-16 Check to see whether your key is bent or twisted, they can be (carefully) straightened in a vice, I've had to do this a few times. The stock ones supplied by Yamaha are quite pliable compared to those you can get cut at Timpsons or wherever. Also, if your key has a transponder fitted for the immobiliser, a Timpson's cut key will not start the bike unless the transponder is close by, such as on the same key ring. Re: ignition key - Sprocket - 28-05-16 It's a common problem - mine was bad initially, free's up with use. Use the search there's a lot of discussion on the forum. I used very small amounts of releasing spray - frequently applied. Re: ignition key - unfazed - 28-05-16 Try Spray on white grease, :thumbup Re: ignition key - Dustydes - 28-05-16 Thanks for all the reply's. After a bit of searching I found that locks should be lubricated with a dry compound such as graphite powder. I'm going to wash out lock with wd40 allow to dry and use graphite powder for locks. Also found on ebay a company that will cut a new key from a scan or photo for £10 A key cut from the original will be cut with the wear from the donor key. These guys work out the code from the key so you get a key that is brand new not a new worn copy. http://www.ebay.co.uk/itm/141988141603?euid=7d9289ef49c84ea8b0f9c37821ef3383&bu=43095947124&cp=1&sojTags=bu=bu Des Re: ignition key - JKay - 28-05-16 I had the same problem and with advice from the guys on here cleaned it out with a good spray of electrical contact cleaner and left for 24 hours and then a decent spray of graphite grease ,and Roberts your dad's brother Re: ignition key - lew600fazer - 30-05-16 (28-05-16, 04:44 PM)Dustydes link Wrote: Thanks for all the reply's. So the immobiliser can be accessed for a £10.00 :eek Re: ignition key - Dustydes - 30-05-16 I don't have the immobilizer on mine Re: ignition key - Dustydes - 03-06-16 Well pleased to say I got the key back today and it works better than the old one. Des |
