Renthal bar ends - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Renthal bar ends (/showthread.php?tid=75746) |
Renthal bar ends - matt7chunk - 25-05-16 Hey, I'm fitting renthal 758s soon and don't like the renthal bar ends they sell, what other bar ends will fit the renthal bars ? Thank you foccers 8) Sent from my GT-I9300 using Tapatalk Re: Renthal bar ends - tex - 25-05-16 I think I had apprila ones on mine worked well, but any to fit 22 bars will work Renthal bar ends - mickvp - 25-05-16 I have got the Oberon stainless steel ones on mine ![]() ![]() http://www.oberon-performance.co.uk/acatalog/Motorcycle_Small_Universal_Bar_End_Weights.html Re: Renthal bar ends - NorthWestern - 25-05-16 I use the renthal plugs as they are clean and don't add width. Think they are £3 ![]() Sent from my SM-G935F using Tapatalk Re: Renthal bar ends - Val - 26-05-16 (25-05-16, 12:59 PM)matt7chunk link Wrote: Hey, No Renthal bars need special smaller diam bar ends. Mine Rentahl 758 was pretty non standard. Some say 13mm will fit. On mine 758 13mm was loose. So I bought these: http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/263556?r=GS&gclid=Cj0KEQjwvZq6BRC9kfq2zKfQ_94BEiQAOeUVC78-VOZJd2XBagvFYFQYtzBuQbTWb8Md1YqAG1A65v0aAphY8P8HAQ And tweaked them with some plastic sleeves to fit. Actual diam was about 14.5 mm.
Re: Renthal bar ends - PieEater - 27-05-16 Take the Renthals to a machine shop and get them tapped out to take the OEM bar ends, cost you about the same as a cheap pair of bar ends but the OEM ones help noticeably with vibrations. Re: Renthal bar ends - celticdog - 28-05-16 I went for these at a fiver from demon tweeks http://www.demon-tweeks.co.uk/Product.do?method=view&n=342&g=241129&p=549366&d=124&c=4&l=2&utm_source=Google&utm_medium=Base&utm_campaign=Bar%20End%20Weights&gclid=CMb1ruOa_MwCFdiZGwodaaAB8A Re: Renthal bar ends - Arfa - 28-05-16 Got some R&G ones on mine, do the job and look alright. Like mini crash bobbins on bars. Do stick out a bit more than others shown here mind. Sent from my HTC One X using Tapatalk Re: Renthal bar ends - matt7chunk - 05-06-16 Ended up get these 13mm red ones from eBay, bars great, no more wrist ache ![]() Sent from my GT-I9300 using Tapatalk Re: Renthal bar ends - celticdog - 05-06-16 Sweet! All you need is some R6 mirrors to complete the look
Re: Renthal bar ends - matt7chunk - 05-06-16 I got some fazer thou mirrors but I found them too big and a big buggy, I was thinking r6 r1 Sent from my GT-I9300 using Tapatalk Re: Renthal bar ends - darrsi - 05-06-16 I have heated grips on my bike, presumably they'd need to be wrecked if i swapped bars? Re: Renthal bar ends - matt7chunk - 05-06-16 If your careful with a small flat head screwdriver you can release the old glue and wiggle them off Sent from my GT-I9300 using Tapatalk Re: Renthal bar ends - matt7chunk - 05-06-16 Or if you have access to a air compressor you can blast air underneath and slide them off Sent from my GT-I9300 using Tapatalk Re: Renthal bar ends - celticdog - 05-06-16 if you can get some wd40 or similar in there (use the wee red straw that always gets lost!) they should come off with a bit of wiggling, Re: Renthal bar ends - darrsi - 05-06-16 The supplied glue was rather useless so i used a heavier duty one, not sure if i'd be able to get them off in good condition, which is a bit of a conundrum as i obviously need them back on immediately. Re: Renthal bar ends - unfazed - 05-06-16 (05-06-16, 10:56 AM)matt7chunk link Wrote: I got some fazer thou mirrors but I found them too big and a big buggy, I was thinking r6 r1 Would you sell the Fazer 1000 ones or do a deal on them I have a set of short R1 mirrors in the garage. Not OEM but in good nick, took them off a Fazer 400 a few years ago. Just noticed the mirror is a loose fit, but a dab of clear silicon would solver that everything thing else is fine. Re: Renthal bar ends - sinto607276 - 05-06-16 (05-06-16, 12:35 PM)darrsi link Wrote: The supplied glue was rather useless so i used a heavier duty one, not sure if i'd be able to get them off in good condition, which is a bit of a conundrum as i obviously need them back on immediately. Switch them onto highest setting to get glue warmed up, try moving the grips, although you used stronger glue they should still move slightly then you can use feeler gauges which won't damage the grips, other thing that is of use is a metal coathanger. Re: Renthal bar ends - matt7chunk - 05-06-16 (05-06-16, 09:51 PM)unfazed link Wrote: [quote author=matt7chunk link=topic=20182.msg233564#msg233564 date=1465120591] Would you sell the Fazer 1000 ones or do a deal on them I have a set of short R1 mirrors in the garage. Not OEM but in good nick, took them off a Fazer 400 a few years ago. Just noticed the mirror is a loose fit, but a dab of clear silicon would solver that everything thing else is fine. [/quote] I'm afraid they have found a new home already unfazed, but I may be interested in your mirrors when payday comes around again Sent from my GT-I9300 using Tapatalk |
