front pads and fluid change - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: front pads and fluid change (/showthread.php?tid=75703) |
front pads and fluid change - celticdog - 20-05-16 Hi guys got new galfer pads so fitting this weekend. :thumbup I've a couple of quick questions for the foccer font of all knowledge! Is it worth me changing from dot 4 to dot 5.1? I use the bike for commuting any thoughts? Also, how much fluid will I need- would a 500ml bottle do or will I need a full litre? Cheers . . . Fellas :rollin :rollin :rollin Re: front pads and fluid change - darrsi - 20-05-16 Blatantly says only use Dot 4 on the master cylinder cap, and the brakes are pretty awesome enough using that, so I don't see why you'd need to try anything else? It's not exactly expensive stuff, just get a litre so you can bleed the brakes properly, always better to have too much than not enough. Re: front pads and fluid change - celticdog - 20-05-16 (20-05-16, 12:48 PM)darrsi link Wrote: Blatantly says only use Dot 4 on the master cylinder cap, and the brakes are pretty awesome enough using that, so I don't see why you'd need to try anything else? Yes dot 4, just wondering if anyone has tried the dot 5.1 mod and how've they got on with it? Re: front pads and fluid change - BBROWN1664 - 20-05-16 5.1 is more for racing. A lot more absorbent to water etc so needs changing more often. In reality, it is no different from DOT4 in use on road bikes. Re: front pads and fluid change - darrsi - 20-05-16 (20-05-16, 12:52 PM)celticdog link Wrote: [quote author=darrsi link=topic=20139.msg232418#msg232418 date=1463744911] Yes dot 4, just wondering if anyone has tried the dot 5.1 mod and how've they got on with it? [/quote] Someone has tried it 'cos I read it on here somewhere in the last few days, but not sure who it was? Found him ![]() http://foc-u.co.uk/index.php/topic,20089.0.html Re: front pads and fluid change - darrsi - 20-05-16 http://foc-u.co.uk/index.php/topic,58.msg172.html#msg172 Re: front pads and fluid change - triker - 20-05-16 Dot 4 500ml enough when I did mine... Re: front pads and fluid change - kgjersda - 28-05-16 (20-05-16, 03:47 PM)darrsi link Wrote: [quote author=celticdog link=topic=20139.msg232420#msg232420 date=1463745130] Yes dot 4, just wondering if anyone has tried the dot 5.1 mod and how've they got on with it? [/quote] Someone has tried it 'cos I read it on here somewhere in the last few days, but not sure who it was? Found him ![]() http://foc-u.co.uk/index.php/topic,20089.0.html [/quote] The guy from the other thread here ![]() The brakes are working 100%, no problems with DOT 5.1 so far (800km). I'd like a little more bite from the brakes, but thats probably just worn out pads. I had no real reason to use 5.1 over DOT 4. Just wanted to try it out. Re: front pads and fluid change - celticdog - 31-05-16 (28-05-16, 09:35 PM)kgjersda link Wrote: The guy from the other thread hereGlad to hear it works ok. In the end I chickened out and went for dot 4 :\ But I'm going to use it on the rear when I next change the pads
Re: front pads and fluid change - darrsi - 01-06-16 (31-05-16, 08:48 PM)celticdog link Wrote: [quote author=kgjersda link=topic=20139.msg233064#msg233064 date=1464467705]Glad to hear it works ok. In the end I chickened out and went for dot 4 :\ But I'm going to use it on the rear when I next change the pads [/quote] Do you really want 'more bite' on the rear? I can understand trying it out at the front, but personally i wouldn't bother using it on the rear just for every day riding. Re: front pads and fluid change - celticdog - 01-06-16 (01-06-16, 05:51 AM)darrsi link Wrote: Do you really want 'more bite' on the rear? I'm strictly old school when it comes to braking darrsi, 80% front 20% rear rising to 50/50% in extremely wet road conditions
Re: front pads and fluid change - JoeRock - 01-06-16 (01-06-16, 05:51 AM)darrsi link Wrote: [quote author=celticdog link=topic=20139.msg233280#msg233280 date=1464724091]Glad to hear it works ok. In the end I chickened out and went for dot 4 :\ But I'm going to use it on the rear when I next change the pads [/quote] Do you really want 'more bite' on the rear? I can understand trying it out at the front, but personally i wouldn't bother using it on the rear just for every day riding. [/quote] Brake fluid will make sod all difference to the bite (comparing 5.1 to 4, I don't mean comparing old to new fluid). Main difference is 5.1 has a higher boiling point, hence why its used on race bikes - you'll never get near the temperatures needed to boil fluid on the road unless you have a serious issue with your braking system. Downside is as pointed out its considerably more hygroscopic so will need bleeding more frequently, which is a bit pointless on a road bike too! Re: front pads and fluid change - darrsi - 01-06-16 (01-06-16, 08:28 AM)JoeRock link Wrote: [quote author=darrsi link=topic=20139.msg233295#msg233295 date=1464756710]Glad to hear it works ok. In the end I chickened out and went for dot 4 :\ But I'm going to use it on the rear when I next change the pads [/quote] Do you really want 'more bite' on the rear? I can understand trying it out at the front, but personally i wouldn't bother using it on the rear just for every day riding. [/quote] Brake fluid will make sod all difference to the bite (comparing 5.1 to 4, I don't mean comparing old to new fluid). Main difference is 5.1 has a higher boiling point, hence why its used on race bikes - you'll never get near the temperatures needed to boil fluid on the road unless you have a serious issue with your braking system. Downside is as pointed out its considerably more hygroscopic so will need bleeding more frequently, which is a bit pointless on a road bike too! [/quote] Sounds like unnecessary hard work to me, for no real gain at all. |
