FZS600 - speedo cable routing - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bits and bobs (https://foc-u.co.uk/mybb/forumdisplay.php?fid=67) +--- Forum: Articles (https://foc-u.co.uk/mybb/forumdisplay.php?fid=85) +---- Forum: FZS600 (https://foc-u.co.uk/mybb/forumdisplay.php?fid=86) +---- Thread: FZS600 - speedo cable routing (/showthread.php?tid=75597) |
FZS600 - speedo cable routing - Iceman - 06-05-16 Hi, Any chance someone could post a pic of the correct cable routing for the speedo pick-up please? Cheers Andy Re: FZS600 - speedo cable routing - Dave48 - 06-05-16 Hi iceman, See you posted this in FZ6 section....However if its the FZS 600 routing I have just taken some pics of "The Red Reviver" showing correct routing of said wire. Check my pic album. Also note the wire passes through a wire loop bracket which is attached to the lower caliper mounting bolt then emerges above the caliper and is clipped to the brake hose in 2 places & then passes up to the lower fork yoke. Hope this helps? Re: FZS600 - speedo cable routing - Iceman - 14-05-16 Hi Dave48, Thanks very much, it's as I thought, but wanted to make sure! Oh and sorry for lobbing it on the wrong forum, not sure what happened there... Andy |
