me again rumbling/metalic sound - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: me again rumbling/metalic sound (/showthread.php?tid=75547) |
me again rumbling/metalic sound - chrischristopherson1313 - 29-04-16 There is a frequent sound from bottom or front of the bike. The frequency is higher when speed is higher. Progress with the speed. It doesn't mater what gear it is or neutral. I thought the is a problem with breaks or bearings but when I wheel the wheel I can't hear anything? Can this sound be from somewhere else then wheel. Re: me again rumbling/metalic sound - joebloggs - 30-04-16 (29-04-16, 11:57 PM)chrischristopherson1313 link Wrote: There is a frequent sound from bottom or front of the bike. Try removing your front wheel and turn the bearing with your fingers, if it has tight spots or feels rough when you turn it then they'll need replacing. May not be your problem but an easy one to check Re: me again rumbling/metalic sound - darrsi - 30-04-16 Not really precise enough, but have you recently done any work on the bike? Re: me again rumbling/metalic sound - chrischristopherson1313 - 30-04-16 (30-04-16, 06:12 AM)darrsi link Wrote: Not really precise enough, but have you recently done any work on the bike? If I know precisely I would fix it ![]() The noise it's constant even when breaks applied. I need to try to go for a hill and go on the bike with engine off then I know if it's engine. I have ordered front bearing they are really cheap anyway. Re: me again rumbling/metalic sound - andybesy - 30-04-16 Could well be the bearings, but binding brakes can cause this too, even when applied. Had that recently and just standard post-winter clean sorted it. Suggest give em a clean at same time as inspecting your bearings. Andy Re: me again rumbling/metalic sound - chrischristopherson1313 - 07-05-16 (30-04-16, 11:57 AM)andybesy link Wrote: Could well be the bearings, but binding brakes can cause this too, even when applied. Had that recently and just standard post-winter clean sorted it. Suggest give em a clean at same time as inspecting your bearings. So it were the bearing. Changed them now ( wasn't easy to take off old one!!!) And bike it's like new
Re: me again rumbling/metalic sound - andybesy - 07-05-16 Good, glad you got it sorted. Andy |
