rear wheel movement issue - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: rear wheel movement issue (/showthread.php?tid=75532) |
rear wheel movement issue - Val - 28-04-16 Hi All, yesterday I was gonna lubricate my chain. And the rear wheel has not turning freely. On center stand and in neutral the wheel turns freely and fine just a little say 4 inches and than stucks and stops suddenly to the point you can't move it with hand, two hands or foot at all. Happens in both directions. I have removed the rear brake caliper - same problem it stucks. I have tried the same with clutch pulled in - same problem. When in 1st gear with clucth pulled in the rear wheel does not moves at all eceb an inch. In neutral moves few inches. The bike rides and feels fine when riding. Clutch seems to engage and disengage the same way it always was before that issue. Can't lubricate my chain though. Any ideas what may be the problem? Thank you in advance. cheers Val Re: rear wheel movement issue - His Dudeness - 28-04-16 You've ruled out the rear brake and disc so I think you've only two things left. The chain and the wheel bearings. Try taking the chain off and see the problem goes. If it doesn't it's probably the wheel bearings Re: rear wheel movement issue - darrsi - 28-04-16 +1 for wheel bearings, although when they're on their way out you should be able to feel and hear them as well. Re: rear wheel movement issue - Jules-C - 28-04-16 Can you move the bike by pushing it? Is the back wheel well of the ground when the bike is on the centrestand? Have you got a hugger fitted? Have you tried running the bike in gear on the centre stand to see if you can spot/hear anything odd Try slackening the rear wheel spindle so it can turn then try moving wheel, if it's seized bearing the wheel should turn more easily. Remember to tighten spindle afterwards before riding bike again! Re: rear wheel movement issue - Val - 28-04-16 (28-04-16, 01:39 PM)Jules-C link Wrote: Can you move the bike by pushing it? Is the back wheel well of the ground when the bike is on the centrestand? Have you got a hugger fitted? Thank you guys. Your suggestion probably will be the right one. Bearing may be the case or something in the rear axle. I have ridden 20 minutes with low pace to the nearest motorcycle garage. The guy (Keith Manning) has loosen the rear axle spindle bolt a little and the wheel moves freely. That discards chain and/or clutch. Either bearing or something else hapenning there. And the bolt and the axle both were very warm. Left it with the mechanic it is too complicated for my skills. I know you will say its easy to change bearing, but I do not have the tools and prefer a mechanic to do that :lol Re: rear wheel movement issue - Punkstig - 28-04-16 Remove the wheel then find a really big Hill, give it a gentle tap at the top of the hill, if it rolls down freely then it's still a wheel, if it's banging and jumping all over the place then it's become a box! Re: rear wheel movement issue - Jules-C - 28-04-16 Sounds like a totally seized bearing. Be as well replacing both wheel bearings and the sprocket carrier bearing Re: rear wheel movement issue - joebloggs - 28-04-16 Get double shielded (rubber) pop one shield off and pack the bearing full of grease. Fit bearing sheild side out. Someone will say they're sealed for life but there's very little grease in them so slar plenty on them and they'll last far longer Re: rear wheel movement issue - Val - 29-04-16 (28-04-16, 09:14 PM)Jules-C link Wrote: Sounds like a totally seized bearing. Be as well replacing both wheel bearings and the sprocket carrier bearing Good call. Just have called the mechanic - it was seized sprocket bearing and I have told him to order the other two as well. Thanks :thumbup |
