EXUP Maintenance - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: EXUP Maintenance (/showthread.php?tid=75442) |
EXUP Maintenance - Tefer - 16-04-16 Hi, I got my FZS1000 last year and have not really done a lot of miles so far. I have been dreading the exup maintenance as I am not that great with a scanner but have been trying more and more lately. Today I got the cover of to show me the cables and pulley. I tried to remove the Allen bolts to all me to look at the valve but they are stuck solid. I have sprayed some WD40 on them and will continue too, is there anything else I can do? I only have an Allen key rather than a Allen socket. I am scared to shear a bolt. Can I heat these? I have been reading the guide from Pats site and this is helpful. P.s one of the 8mm bolts is missing, where can I source a replacement. Re: EXUP Maintenance - Falcon 269 - 16-04-16 Full marks for having a go but this isn't a task to take on without the right tools and - if the bolts are seized - perhaps a bit of prior experience of dealing with difficult extractions. WD40 isn't good enough as a penetrating oil and even with the right stuff, you still will need a proper-fitting socket head wrench. The odds are still pretty high that you'll troubles with sheared off bolt heads. ![]() Lots of 'how to' posts on the forums - here's one I made earlier dealing with two very recalcitrant R1 EXUPs, which are identical to the Fazer's: http://fazerowners.yuku.com/topic/21517 Good luck! ![]() Re: EXUP Maintenance - Tefer - 17-04-16 Hi Mike, Thanks ordered some plusgas and will use this to soak the stuff over a prolonged period. Partners brother is a motor mechanic so will have better tools and knowledge of problematic extractions. I see in some of the comments in the link you posted it mentions replacing the old and replacing with stainless, top of your head any sizes and types so I can order too? Re: EXUP Maintenance - Tefer - 17-04-16 Some pics. Re: EXUP Maintenance - Falcon 269 - 17-04-16 Top of my head? M6 x 10mm should be about right for the pulley cover, maybe a bit longer for the valve end plate. Re: EXUP Maintenance - robbo - 18-04-16 Measured the necessary bolts only the other week.The cover is M6 x 10mm the valve M6 x 16mm the pulley centre is M5 x 12mm and the cover on the other end of the valve (RH side of the bike) is M4 x 6mm. Re: EXUP Maintenance - Tefer - 18-04-16 (18-04-16, 09:17 AM)robbo link Wrote: Measured the necessary bolts only the other week.The cover is M6 x 10mm the valve M6 x 16mm the pulley centre is M5 x 12mm and the cover on the other end of the valve (RH side of the bike) is M4 x 6mm. Thanks man |
