Hi (new fazer owner) - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: Introduction (https://foc-u.co.uk/mybb/forumdisplay.php?fid=68) +--- Thread: Hi (new fazer owner) (/showthread.php?tid=75398) |
Hi (new fazer owner) - matt7chunk - 11-04-16 Hi nice to meet you all, I just sold my little 125 and purchased a fzs600 1999 model , I think the bike is beautiful and can't wait to ride her, Mod1 end of the month then mod2 shortly afterwards So all I can do atm is polish her and play with her , I changed the screen bolts for red ones and also the levers , going for a red/black theme , here's some pics, tell me what you think and any advice would greatly appreciated ![]() ![]() ![]() ![]() Sent from my iPad using Tapatalk Re: Hi (new fazer owner) - Val - 17-04-16 Hello and welcome Nice bike :thumbup The most important mod for the Fazer is to check the front sprocket nut. There has been upgrade to 12mm. If you decide to change it probably its good idea to change the chain and the sprockets too: http://foc-u.co.uk/index.php/topic,17673.msg204017.html#msg204017 The new nut is higher and looks like this almost level with the shaft: http://foc-u.co.uk/index.php?topic=11851.0 ![]() Here is the old one note the shaft going above the nut few mm: ![]() Good luck on the tests! Where are you based? Re: Hi (new fazer owner) - matt7chunk - 17-04-16 Brilliant, great info Val thank you, I'll be taking a peek under the sprocket cover on my next day off , I'm based in Suffolk country side near Ipswich , are you nearby? Sent from my iPad using Tapatalk Re: Hi (new fazer owner) - Val - 18-04-16 (17-04-16, 09:01 PM)matt7chunk link Wrote: Brilliant, great info Val thank you, I'll be taking a peek under the sprocket cover on my next day off , you welcome Matt. Not very close I am in Bracknell. You can add your location in your profile. I like this forum feature. And you can see on the forum's member map foccers near you http://foc-u.co.uk/index.php?action=googlemap Re: Hi (new fazer owner) - matt7chunk - 20-04-16 Looked behind the sprocket cover and yup 9mm nut , will be investing in a 12mm on payday , The bikes done 27000 miles on the standard nut , what's the chances of it being one of the good ones? Sent from my iPad using Tapatalk Re: Hi (new fazer owner) - Val - 22-04-16 (20-04-16, 10:59 PM)matt7chunk link Wrote: Looked behind the sprocket cover and yup 9mm nut , will be investing in a 12mm on payday , Actually the chances are very good. Most likely you will be fine with the old 9mm nut. I would not go for nut only change job. To me make sense to change it together with the chain and sprockets when you have a new ones. Re: Hi (new fazer owner) - matt7chunk - 22-04-16 Great that was my thought also Sent from my GT-I9300 using Tapatalk Re: Hi (new fazer owner) - matt7chunk - 22-04-16 Passed mod 1, one step closer to riding my beautiful fazer (itching lol) Sent from my GT-I9300 using Tapatalk |
