Front Sprocket - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: Introduction (https://foc-u.co.uk/mybb/forumdisplay.php?fid=68) +--- Thread: Front Sprocket (/showthread.php?tid=75383) |
Front Sprocket - tommyardin - 11-04-16 Hello Gentlemen, Can anyone tell me how the f--k do you get the front sprocket off my 02/03 fzs600. I purchased the new modified sprocket nut and washer from Yamaha and have tried a couple of times to undo the sprocket retaining nut, I think the Incredible Hulk fitted it originally. I am assuming it is a standard right hand thread. 32mm socket and a 500mm extension lever, I am frightened to apply any more force than I have thus far for fear of snapping something. I have left it for now as I have rightly or wrongly reasoned that as its that tight it's not likely to cause a problem. I have read about all sorts of nasty things happening when problems occurred with the nut. I am 12st 10lbs in weight and a retired bricky so I am not adversed to applying a little force, but have shivered at the thought of snapping or stripping a thread on the shaft. Am I just being a tart and should I go for it? Advice welcome and I am aware that the ultimate decision rests with me. Someone said put a gas torch on it but not going down that route as it seems to me to risky, firstly removing any hardening and tempering from the shaft itself and or screwing any oil seals in the vicinity. :'( Re: Front Sprocket - Dave48 - 11-04-16 Found the same problem myself in February -had purchased the upgraded 12mm nut/washer in anticipation. When I tried to undo existing nut I was on my own so put soft piece of wood between wheel spoke & swingarm. Fitted 600mm extension bar and a length of steel scaffold pipe over this--couldnt budge the f****r ! So like you reasoned that if brute force & ignorance wont move it then I will leave until such time as sprocket needs replacing & get local friendly garage to shock it loose with air tool ! Re: Front Sprocket - tommyardin - 13-04-16 (11-04-16, 11:07 AM)Dave48 link Wrote: Found the same problem myself in February -had purchased the upgraded 12mm nut/washer in anticipation. Thanks for your thoughts on the sprocket issue, I am going to do likewise and leave it until such time as the drive train needs replacing. I tried to undo it wi.th bike in 1st gear mate sat on bike with front and rear brakes held on, still no joy, don't think that bad boy is going to come loose in a hurry. :groan Hope I'm right about that. I heard of one guy welding them sprocket onto the sharft after his threads had stripped. Bit drastic. Re: Front Sprocket - Val - 17-04-16 (11-04-16, 08:50 AM)tommyardin link Wrote: Hello Gentlemen, If somebody has applied loctite to it 500mm lever will do nothing. You need a pipe at least 1 meter long. Stop the rear wheel with some wood on the swingarm, like I have used hammer handle wrapped in old t-shirt. Make sure you have straighten the washer first. Have you done that? There is an washer below the nut which is bend to prevent unscrew. You need to starighten it with a big screwdriver and a hammer first. Than go for it with the 1m pipe extension. It is tight but will go off. Let friend of yours seat on the bike or if alone like I have done it, you push hard with your left hand down on the socket and with right hand upwards with the pipe making sure you do not overturn the whole bike. Re: Front Sprocket - tommyardin - 19-04-16 (17-04-16, 07:56 PM)Val link Wrote: [quote author=tommyardin link=topic=19819.msg228922#msg228922 date=1460361036] If somebody has applied loctite to it 500mm lever will do nothing. You need a pipe at least 1 meter long. Stop the rear wheel with some wood on the swingarm, like I have used hammer handle wrapped in old t-shirt. Make sure you have straighten the washer first. Have you done that? There is an washer below the nut which is bend to prevent unscrew. You need to starighten it with a big screwdriver and a hammer first. Than go for it with the 1m pipe extension. It is tight but will go off. Let friend of yours seat on the bike or if alone like I have done it, you push hard with your left hand down on the socket and with right hand upwards with the pipe making sure you do not overturn the whole bike. [/quote] Cheers for the advice Val I will give it a go at some point. I do have the Upgrade nut and washer now (12mm), the one that was supplied by Yamaha was a 9mm nut the same as the original, it may of been my fault as I asked for a replacement nut and washer for the sprocket and I guess they just gave me the nut to replace the original, I should have asked for the upgraded nut and washer set. But to be honest I feel as if I am being generous to them. BASTARDS :eek Re: Front Sprocket - tommyardin - 19-04-16 Is it really 94KN :grumble torque to the front sprocket nut. I have a Britool EVT600A rachet torque wrench but it goes up to 68KN or 50 lbfft or 600 lbfin. Re: Front Sprocket - joebloggs - 20-04-16 Pop down your local garage with your 32mm socket in hand and ask them to loosen it with their impact wrench, re tighten and remove when you get home Re: Front Sprocket - tommyardin - 20-04-16 (20-04-16, 01:05 AM)joebloggs link Wrote: Pop down your local garage with your 32mm socket in hand and ask them to loosen it with their impact wrench, re tighten and remove when you get home Hey Joe sounds like a plan to me. X Re: Front Sprocket - chaz - 20-04-16 QUOTE I heard of one guy welding them sprocket onto the sharft after his threads had stripped. Bit drastic. who would do a thing like that............. me this was the second sprocket welded on the first one did 22,000 miles, the welding on the end of the shaft/nut is just to tack it on, the weld on the sprocket/nut is to stop it "chattering" on the splines, it doesn't matter now as I came off the bike due to diesel on the road and the bike was written off. Re: Front Sprocket - tommyardin - 22-04-16 (20-04-16, 09:04 PM)chaz link Wrote: QUOTE I heard of one guy welding them sprocket onto the sharft after his threads had stripped. Bit drastic. Sorry to hear that Chaz, the bike is replaceable but you obviously survived and that cool cos you aint replaceable. Same as the rest of us, individual and unique. :rolleyes [size=1em]all irreplaceable one offs.[/size] [size=1em]But did you replace the [/size] :faz ? Re: Front Sprocket - chaz - 28-04-16 No haven't replaced the fazer, still got another bike to ride, been looking at MT09 but not sure, theres two FZ8s in Jax York. I'm having a think about riding in a squad this year as still not fit. Just read that the "Harrogate Lads" father and son have got a 70 day ban and each been fined over a £1000 each for doing 110 mph. Unmarked police bike followed them, police said as the season starts they will be out after the speeders, it's a pitty the police didn't put a bit of effort into finding who split loads of deisel on the road when I came off, when I say loads there must have been gallons as I was told that I slid 50 to 70 feet before I hit the car coming towards me and I was still laid in diesel? there's a yard a mile up the road where they sell old plant and vehicals proberbly been one of those? but can't prove it. Re: Front Sprocket - tommyardin - 28-04-16 (28-04-16, 11:20 PM)chaz link Wrote: No haven't replaced the fazer, still got another bike to ride, been looking at MT09 but not sure, theres two FZ8s in Jax York. I'm having a think about riding in a squad this year as still not fit. Just read that the "Harrogate Lads" father and son have got a 70 day ban and each been fined over a £1000 each for doing 110 mph. Unmarked police bike followed them, police said as the season starts they will be out after the speeders, it's a pitty the police didn't put a bit of effort into finding who split loads of deisel on the road when I came off, when I say loads there must have been gallons as I was told that I slid 50 to 70 feet before I hit the car coming towards me and I was still laid in diesel? there's a yard a mile up the road where they sell old plant and vehicals proberbly been one of those? but can't prove it. Well Chaz i'm glad your on the mend buddy I hope you will be up and about riding again soon. Don't know anything about the bike you mentioned I have seen pics of the MT but know nothing about the specs is it a 4 or a twin? |
