Annoying noise when rolling - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Annoying noise when rolling (/showthread.php?tid=75355) |
Annoying noise when rolling - gerkin - 07-04-16 I have a noise similar to bodywork vibrating and slight vibes but only below 5k revs Don't make the noise when on centre stand in neutral or in gear Suspected loose sprocket but which is tight output bearing seems fine Removed clutch checked all OK Brake pads appear OK is not loose and vibrating No mudguards rubbing Could it be water pump ? Really starting to p me off Help!!! Cheers gaz Re: Annoying noise when rolling - darrsi - 07-04-16 Wing mirror glass, indicators, front fairing shield, infill panels on fairing. Check engine mounting bolts are done up okay. Re: Annoying noise when rolling - gerkin - 07-04-16 Engine change Xmas 2015 checked all bolts the front mountings for the dhm mushrooms were slightly loose now tightened Enough to cause the vibes? ,here's hoping ! ,pissing down here will test on my commute in the morning Cheers Re: Annoying noise when rolling - Frosties - 07-04-16 (07-04-16, 06:40 PM)gerkin link Wrote: I have a noise similar to bodywork vibrating and slight vibes but only below 5k revs Not missing the centre stand rubber stop for when it's up? Re: Annoying noise when rolling - gerkin - 08-04-16 Road tested today noise still there Centre stand bung missing will fit gaffer tape something on and see if that cures it Cheers gaz Re: Annoying noise when rolling - gerkin - 08-04-16 Put some off cuts of rubber between exhaust and centre stand cable tied tight noise still there Dam n blast Re: Annoying noise when rolling - sgpwwg - 08-04-16 I had the same issue with a buzzing only a certain revs and it turned out to be the screws that hold the screen where old and loose. Got some new ones job done. Could be worth a try. Re: Annoying noise when rolling - tommyardin - 08-04-16 (07-04-16, 06:46 PM)darrsi link Wrote: Wing mirror glass, indicators, front fairing shield, infill panels on fairing. That would be well worth checking front screen, just grab it with one hand while riding. I had my GoPro mounted on the screen down low on outside in front of clocks and camera always had a loud buzzing noise and that is what it turned out to be screen vibes. I replaced them screen screws and rubber screw fixings and hey presto vibes gone. You can make a nice feature of the screen screws by getting colour coded ones to suit bike colour scheme, 9 quid on eBay. Certainly worth checking only takes a second while riding along. A mate also had the same problem and he put double sided tape between the screen edge and the fairing edge that sorted his out, if you are carefull it's not even noticeable. Re: Annoying noise when rolling - darrsi - 09-04-16 I've always used small strips of the softer sided velcro to put in between vibrating plastics. Re: Annoying noise when rolling - gerkin - 10-04-16 Think this may be chain noise ,hardly any wear when tested at the rear sprocket only about 5mm daylight between sprocket and chain ,But loads of sideways movement and looks like there is 1mm of slight wear on the tyre edge wear chain may have been rubbing ,never had anything like this in 30 years of riding ,will fit new c&s and check back ! Cheers for all your replies Re: Annoying noise when rolling - darrsi - 10-04-16 (10-04-16, 06:01 PM)gerkin link Wrote: Think this may be chain noise ,hardly any wear when tested at the rear sprocket only about 5mm daylight between sprocket and chain ,But loads of sideways movement and looks like there is 1mm of slight wear on the tyre edge wear chain may have been rubbing ,never had anything like this in 30 years of riding ,will fit new c&s and check back ! Have you had the rear wheel off recently, or adjusted it at all? Re: Annoying noise when rolling - gerkin - 18-01-20 Reply to old post this was my old fazer sold years ago, which I sold in parts as I could not trust that something was gonna break Have had another for just over a year ,this developed the same noise Turned out to be lack of grease in speedo drive in front wheel Big thanks to MTREAD for the heads up Re: Annoying noise when rolling - gerkin - 24-04-22 Similar thread started recently |
