What bulb is the Low beam?! - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: What bulb is the Low beam?! (/showthread.php?tid=75340) |
What bulb is the Low beam?! - Tubz1983 - 06-04-16 This is going to sound quite uninformed but hey we all have to learn, just fitted a better main beam bulb ( h4 night breaker ) got 2x in a pack but what can I replace the low beam with, what am I searching for on eBay etc? As its obviously a thinner bulb than th high beam and won't fit through the gap in the headlight unit? So the main bulb is a brilliant white and the other a piss yellow atmĀ Thanks again? Re: What bulb is the Low beam?! - darrsi - 06-04-16 H1 Re: What bulb is the Low beam?! - Tubz1983 - 06-04-16 Appreciated thank you ordered a couple. T
Re: What bulb is the Low beam?! - mattrain - 06-04-16 Hi Tubz, might also be worth chcking forum for previous posts about re-wiring so both bulbs come on for low beam, I upgraded my bulbs but made little difference, the standard box eye beam pattern doesn't lend well to seeing in the dark ? imo. Re: What bulb is the Low beam?! - darrsi - 07-04-16 (06-04-16, 09:16 PM)mattrain link Wrote: Hi Tubz, might also be worth chcking forum for previous posts about re-wiring so both bulbs come on for low beam, I upgraded my bulbs but made little difference, the standard box eye beam pattern doesn't lend well to seeing in the dark ? imo. It's the reflective part of the headlight unit that is the problem, in a word it is shite. Re: What bulb is the Low beam?! - Paulfzs - 07-04-16 (07-04-16, 06:57 AM)darrsi link Wrote: [quote author=mattrain link=topic=19776.msg228592#msg228592 date=1459973780] It's the reflective part of the headlight unit that is the problem, in a word it is shite. [/quote] pretty much this, the reflectors are shockingly shite, even with a hid bulb its pathetic. |
