Clutch problems..... - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Clutch problems..... (/showthread.php?tid=75322) |
Clutch problems..... - Trip - 03-04-16 I'm sat in an AA van as I write this, I passed my test last August and went out and bought an 03 fazer which I instantly fell in love with. Today however she's breaking my heart. Riding along my and the clutch lever wouldn't work, I could move it but it was loose and not doing what a clutch lever should.... Thinking the cable must have snapped I killed the engine and pulled over, as I did so, I saw a big pool of oil appear below the gear lever. Any thoughts as to what this could be? Any help or advice would be appreciated! Re: Clutch problems..... - Deefer666 - 03-04-16 Sounds like a problem with the clutch push rod where it goes into the engine under the front sprocket housing... Are you sure the chain hasnt snapped? Re: Clutch problems..... - Trip - 03-04-16 Thanks Deefer, No I'm not 100% certain, but would this cause an oil leak? I'm not talking a couple of drops, this was a puddle (all over by back wheel too ! ?) Re: Clutch problems..... - Bretty - 04-04-16 I've had something similar happen to me on a long ride back from Hamburg. My scottoiler ran dry, chain stretched, jumped a tooth on the front sprocket and hit the push rod, snapping it and dislodging the seal. I don't remember a lot of oil coming out though? But this would be my guess. Re: Clutch problems..... - Deefer666 - 04-04-16 (04-04-16, 08:50 AM)Bretty link Wrote: I've had something similar happen to me on a long ride back from Hamburg. Tha'ts what I'm thinking... take your sprocket housing off and in front of the sprocket you should see a rod coming out of the engine, if there is just a hole that is leaking oil then your chain has either snapped or jumped and knocked the top off of the clutch push rod. I have also seen this happen when the front sprocket retaining nut has failed. Re: Clutch problems..... - Trip - 10-04-16 Thanks for the input guys, you were quite right, it was a sheared push rod. Chain was intact though. |
