rear wheel bearings - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: rear wheel bearings (/showthread.php?tid=75306) |
rear wheel bearings - gnm - 01-04-16 hi all, just noticed a bit of play on rear wheel bearings, has anyone used the all balls kit from wemoto? also any problems fitting or any special tools needed to fit them? Re: rear wheel bearings - unfazed - 01-04-16 The right side is what usually goes and that bearing is a 60/28 2RS C3 sealed race ball bearing Replace the seal also 35mm x 52mm x 8mm seal They are fairly standard bearing and seal, local bearing shops will probably have them in stock. Go for know brands Re: rear wheel bearings - red98 - 02-04-16 yup....ive used the "all balls" bearings on both my thou and 6....no problems fitting and look to be good quality....done probs 2k with them and no problems :thumbup Re: rear wheel bearings - gnm - 02-04-16 thanks for that, probably just change all when wheels off anyway. |
