More Exup woes and cheap Exup Cables - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: More Exup woes and cheap Exup Cables (/showthread.php?tid=75257) |
More Exup woes and cheap Exup Cables - Neon Knight - 27-03-16 When checking my Exup for the first time the other day I was dismayed to find it's in quite a bad state. Only one of the 3 bolts holding on the cover was still there, other 2 broken off in the casing by the previous owner of the bike, it gets better, the two allen bolts that hold the actual Exup valve in the exhaust body are completely rounded off inside and so badly corroded I seriously think they will snap if I try and get them out. If that wasn't bad enough, I also noticed a significant amount of slack in both cables, so after spraying the pulley and cables with enough wd40 to cook an egg I decided to adjust the cables to take out this slack. More trouble followed, both the cables had obviously never been adjusted and were quite tight,a bit more wd40 I thought. I managed to slacken one off without too many swear words but the other alas no. As I began to adjust the cable the bloody thread on the adjuster snapped off inside the adjuster itself. As Mr Hugh Grant would say "bugger bugger bugger". I therefore have to replace the Exup cables now and I nearly had a heart attack when I saw the price. I did find a cheaper alternative on Flea Bay but I dont know much about them, are they worth a gamble ? :rolleyes Any advice or help greatly appreciated :'( Re: More Exup woes and cheap Exup Cables - tex - 27-03-16 There's some on ebay brooks barns, item number 331760942781 £34 , don't know if they are genuine, or any good , at that price worth a punt. I have a spare set in the shed, yours for £50 . Re: More Exup woes and cheap Exup Cables - AyJay - 27-03-16 I've had some Wemoto 'SlinkyGlide' cables on mine for about 40k miles. they work, but they're not quite up to the originals in terms of build. But 50 quid for 40k miles isn't too bad and they haven't broken yet, they just needed a lot of adjustment to begin with whilst they bedded in and stretched a bit. |
