EXUP Question - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: EXUP Question (/showthread.php?tid=75218) |
EXUP Question - Neon Knight - 23-03-16 Do you get the same tacho error message if the exup is stuck open as you would if it was stuck closed ? :rolleyes Re: EXUP Question - Falcon 269 - 23-03-16 Yes. The code tells you that the servo can't turn and has shut down to avoid damaging itself. The cause can be incorrect cable adjustment, a stuck valve or sticking cables. The outcome is the same. Re: EXUP Question - Neon Knight - 25-03-16 Cheers Mike :thumbup |
