Rough suspension settings for 50mm rear lift? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Rough suspension settings for 50mm rear lift? (/showthread.php?tid=75160) |
Rough suspension settings for 50mm rear lift? - Motopsycho87 - 14-03-16 Standard suspension still, just wondering if anyone has a baseline I can fine tune from? 95kg of British boeuf! Re: Rough suspension settings for 50mm rear lift? - sadlonelygit - 16-03-16 Firstly, @95kg you are too heavy for a standard spring. Secondly, shortening the dogbones will soften the suspension even further iirc. 50mm is too high unless you are going for the German fighter look Re: Rough suspension settings for 50mm rear lift? - Motopsycho87 - 16-03-16 It feels a lot better and is pretty stiff tbf, the preload is about mid point, so I'm thinking the springs may have been swapped at some point. Getting the dirt bike suspension soon sorted this week so I'll worry about the roady soon. Re: Rough suspension settings for 50mm rear lift? - tommyardin - 16-03-16 (14-03-16, 06:13 PM)Motopsycho87 link Wrote: Standard suspension still, just wondering if anyone has a baseline I can fine tune from? 95kg of British boeuf! 79.54 Kilo Racing Snake here, I think you need a cattle wagon. lol! Oh! and hello Moto. :rollin Re: Rough suspension settings for 50mm rear lift? - Motopsycho87 - 16-03-16 Cheeky **** , I'll do my sag settings on the weekend and find out for certain!
Re: Rough suspension settings for 50mm rear lift? - PieEater - 16-03-16 Yup shorter dog bones make the rear shock feel stiffer, I think it has an affects on the compression somehow. It's a good way to get the rear feeling that little bit more up to the job. I have a 25mm jack-up kit fitted but have a Nitron shock so cant help out with suspension settings but I'd suggest keeping the preload up and decreasing the compression damping if it feels on the firm side. I'm probably going to get the 50mm kit when I can afford it as I have my Nitron on maximum ride height and would prefer a bit more control over this which the even shorter dog bones would allow. |
