Home made chain riveter!! - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Home made chain riveter!! (/showthread.php?tid=75129) |
Home made chain riveter!! - chunk166 - 09-03-16 Ok Guys 'n' Girls, I have made my own chain riveting tool thanks to Youtube for some ideas :lol Now as i like to do as much of my own work on my bike as i can (I'm a tight Foccer!) I have added a couple of pics & i just want to ask you if you think that it'll do the job!!! :eek :eek :eek Thank you for your opinions in advance Re: Home made chain riveter!! - pilninggas - 09-03-16 It might work. Those generic chain tools have presses that fit 5/8 chain sideplates properly so the process does not deform the sideplates or crush the o-rings. I tend to only use a chain tool to withdraw the pins from a rivet on the chain I am replacing (having ground the tops off) and to press the new link on (I wonder if your tool will do this). To peen the pins over on the new soft link I put a heavy hammer behind it and use a punch to peen 4 edges over, I then check with a caliper the peening has worked and the sideplate is secure. Re: Home made chain riveter!! - chunk166 - 09-03-16 I have a tool to push the sideplate on, i made this as the link supplied is a hollow ended & i am hoping that this will open (flange) the pins out, obviously i will check with a vernier caliper as to make sure its enough to make it safe! :eek Re: Home made chain riveter!! - celticdog - 09-03-16 needs more duct tape
Re: Home made chain riveter!! - Val - 09-03-16 (09-03-16, 08:13 PM)celticdog link Wrote: needs more duct tape Or instead of riveting you can use the duct tape directly with the chain. Problem solved. Re: Home made chain riveter!! - chunk166 - 09-03-16 I've run out of duct tape, was thinking of using blu tack but i'm not sure its strong enough :lol |
