tyre pressure - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: tyre pressure (/showthread.php?tid=75123) |
tyre pressure - stu1318 - 08-03-16 whats the recommended tyre pressures...cheers Re: tyre pressure - Don71uk - 08-03-16 36 psi front 42 rear Thats what I run with Dunlop Roadsmarts, on a Gen 1. Re: tyre pressure - Tmation - 08-03-16 Go to the downloads section on here and get yourself a copy of the owners manual if your bike didn't come with one Re: tyre pressure - stu1318 - 08-03-16 cheers lads
Re: tyre pressure - unfazed - 08-03-16 (08-03-16, 05:55 PM)stu1318 link Wrote: whats the recommended tyre pressures...cheers Can depend on the tyres you have on it, but standard pressures are: Front: 2.5 bar (36psi) at all times Rear: 2.7 Bar (39psi) Rear: 2.9 bar (42psi) with two up and/or sustained high speed riding Example: Michelin are 2.3 bar front and 2.5 bar rear one up, but are 2.5 bar front and 2.9 bar two up Bridgestone are 2.5 bar front and 2.9 bar rear for everything Metzler are 2.5 bar front and 2.9 bar rear for everything Dunlop use the standard pressures Track day pressures will be different again |
