Rear tire 180? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Rear tire 180? (/showthread.php?tid=75092) |
Rear tire 180? - NikolaFazer - 04-03-16 Hey folks, it's time to change tires and I want to put 180 mm rear tire. Is it possible? There is enough space between tire and rear fork, but not too much between tire and chain. Did someone managed do fit it? Re: Rear tire 180? - Gnasher - 04-03-16 (04-03-16, 12:57 PM)NikolaFazer link Wrote: Hey folks, it's time to change tires and I want to put 180 mm rear tire. Is it possible? There is enough space between tire and rear fork, but not too much between tire and chain. Did someone managed do fit it? It might depending on the make as makes differ, they say 180 but when you measure they're less or more :eek The limiting factor here is the rim width the rim on OE wheels is too small your handling will be effected how much who knows but it will effect it especially at speed even in a straight line but without doubt when cornering. [/size][size=78%] [/size] Re: Rear tire 180? - joebloggs - 05-03-16 A 180 wont improve the size of your cock Re: Rear tire 180? - NikolaFazer - 05-03-16 Luckily that part doesn't need any improvement. Thank you for your suggestion. Just looking a way to improve my bikes look. Cheers. Re: Rear tire 180? - darrsi - 05-03-16 You need one of these..... :b Re: Rear tire 180? - celticdog - 05-03-16 Now that certainly is a bigger rear end! Re: Rear tire 180? - fazersharp - 05-03-16 That's disgusting, those rear peg hangers could do with a dam good polish Reminds me did you try using that handle we see there to put the centre stand on And Nicolafazer just keep the OEM spec Re: Rear tire 180? - TheMuffinRanger - 20-03-16 I agree don't mess with tyres out of spec done it on my old gixxer was ok ish. But really changed the handling and actually made the tyre look smaller cause of how the it sat on the rim an even on track I couldn't lose the chicken strips ? Re: Rear tire 180? - Val - 20-03-16 (05-03-16, 09:02 AM)darrsi link Wrote: You need one of these..... :b These are very hard run flat tyres :lol Re: Rear tire 180? - tommyardin - 31-03-16 (05-03-16, 09:02 AM)darrsi link Wrote: You need one of these..... :b Is that the new Hugger :eek |
