Blue dot rear brake - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Blue dot rear brake (/showthread.php?tid=75089) |
Blue dot rear brake - msewelly - 03-03-16 Hi, Doing a bit of maintenance work on the rear caliper. The rear caliper has clearly not seen a good clean in a while and has a fair amount of corrosion. Even the retaining pins were a huge task to remove, one piston was sticking which I've managed to free up with lots of cleaning and greasing. A question I do have is how do I remove the corrosion on the inner part of the pistons, Its most likely only surface rust but I'd rather remove it to stop it worsening. Thanks! Re: Blue dot rear brake - Falcon 269 - 03-03-16 Remove and clean the pistons, check the caliper bores and replace the pistons. Probably worth fitting new seals while you're at it. |
