Brake Reservoir hose ID - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Brake Reservoir hose ID (/showthread.php?tid=75042) |
Brake Reservoir hose ID - Adam2201 - 26-02-16 Has anyone ever had to replace the rubber hose from the brake reservoir to the rear master cylinder? I noticed a bit of brake fluid on mine today - it could just be that the reservoir was just disturbed when I fitted my stainless hoses so I will check the clamps and have another look at it tomorrow, but since the rubber is likely to be original to the bike it can't be a bad idea to replace it at 17 years old, even if it's not under great pressure. I wouldn't mind paying £10.00 for a Yamaha part from Fowlers or AJ Sutton, but as it's on special order from Japan, I'm wondering if anyone happens to know the internal diameter of the hose so I can just order a metre of rubber brake hose to cut down? I'm guessing from the part number: [color=rgb(154, 154, 154)]5DM-25895-00[/color] it's 3/8 ID (9.5mm)? the 5DM is the bike designation and the 258 seems to be 'brake hose' looking at similar parts? Many thanks in advance. |
