simple task for fzs owner - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: simple task for fzs owner (/showthread.php?tid=74996) |
simple task for fzs owner - SVouros - 19-02-16 Ok, here is the problem. Spyball alarm went at the bin. (cause the remote is dead, pin is lost, etc etc) I need to see from the inside of this cap (something like the picture) The local dealer said this part is not available as spare (!!!) anyway, this is a 6 pin connector, with a top cap that bridges to 2 pins (i think). Problem is that i don't know which of them to bridge. This fuse is located by the left side of the bike, somewhere along with the indicators fuze, under the saddle. Please any kind of help would appreciated. Re: simple task for fzs owner - unfazed - 19-02-16 Which spyball model did you have? Are there two set of connectors one with 6 pins and one with 8 pins? Do you have a picture of the connectors you removed from the alarm? Re: simple task for fzs owner - SVouros - 19-02-16 Which spyball model did you have? type 6527 -that's the label Are there two set of connectors one with 6 pins and one with 8 pins? no (1) this the connectors from the alarm (2) the connectors on bike for the 6 pin one, i need to see the inside of the cap (that should be something like the black cap - first from the left- for the third connector) Re: simple task for fzs owner - unfazed - 19-02-16 Cut the 2 plugs off the alarm cable leads about 3 inches back from the plugs, this will give you room to join the necessary wires. Send me a pm with your email address and I will send you a picture of the bypass plugs Re: simple task for fzs owner - SVouros - 20-02-16 problem solved thanks to unfazed Re: simple task for fzs owner - unfazed - 20-02-16 :thumbup :thumbup |
