Fazer 2002 .What RPM doing Carburetor Synchronization? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Fazer 2002 .What RPM doing Carburetor Synchronization? (/showthread.php?tid=74948) |
Fazer 2002 .What RPM doing Carburetor Synchronization? - Irmantas - 13-02-16 Hello my friends. What RPM have to be doing Carburetor Synchronization? 1050-1150? Re: Fazer 2002 .What RPM doing Carburetor Synchronization? - Irmantas - 13-02-16 and maybe someone have pictures wheare is that three hiding bolts? )
Re: Fazer 2002 .What RPM doing Carburetor Synchronization? - Falcon 269 - 13-02-16 1150 - 1250 is a better idle speed and that's what I use for carb synch. No pictures - too dark! You need a flashlight to search for the synch screws but they are there to be found.
Re: Fazer 2002 .What RPM doing Carburetor Synchronization? - Motopsycho87 - 14-02-16 Ordered some gauges for mine today. It won't even idle properly below 1500rpm so def needs doing... Re: Fazer 2002 .What RPM doing Carburetor Synchronization? - PieEater - 14-02-16 Pat's site has a section on synching the carbs with some pictures which might help - http://www.cartestsoftware.com/fz1/carburetorsynchronization.html Re: Fazer 2002 .What RPM doing Carburetor Synchronization? - Irmantas - 14-02-16 ok , thanks for help friends , just one more question , what RPM have to be on free engine running ? "no acceleration"
Re: Fazer 2002 .What RPM doing Carburetor Synchronization? - PieEater - 14-02-16 (14-02-16, 09:07 AM)Irmantas link Wrote: ok , thanks for help friends What Falcon 269 said 1150 - 1250rpm Re: Fazer 2002 .What RPM doing Carburetor Synchronization? - slappy - 14-02-16 You will need a long screwdriver to reach all the adjusting screws
Re: Fazer 2002 .What RPM doing Carburetor Synchronization? - Irmantas - 14-02-16 i mean what rpm have to be after synchronization :rolleyes Re: Fazer 2002 .What RPM doing Carburetor Synchronization? - Falcon 269 - 14-02-16 1200rpm is good. A bit higher than Yamaha say but keeps the oil pressure up at idle.
Re: Fazer 2002 .What RPM doing Carburetor Synchronization? - PaulSmith - 15-02-16 To find the middle screw can be a challenge. Look for the metal bracket with the section cut out between the middle carbs. Now shine your torch over the connectors on your coil through that notch. If you look along the beam of light, you should be able to see the screw. Re: Fazer 2002 .What RPM doing Carburetor Synchronization? - markie_wales - 15-02-16 Yeah it's all coming back to me now! The last 9 years on KTM's with one, sticking out easy to find, screw has spoilt me Re: Fazer 2002 .What RPM doing Carburetor Synchronization? - Irmantas - 16-02-16 Roger that . And what synchronizer you reccomend ? bottle or clear plastic vinyl tube ? :rolleyes
Re: Fazer 2002 .What RPM doing Carburetor Synchronization? - PaulSmith - 16-02-16 I prefer the rods to the dials, but that is because I have had my carbtune for years and have never used one of the others. I don't think there is a big difference between them. |
