Front Sprocket Nut & Lockwasher Part Nos - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Front Sprocket Nut & Lockwasher Part Nos (/showthread.php?tid=74925) |
Front Sprocket Nut & Lockwasher Part Nos - Dave48 - 10-02-16 Recently ordered the 12mm nut & tab washer upgrade kit from my local dealer. The combined kit carries the Yamaha part no 90891-10124 & retails @ £2-44. However the kit contained the 2 individually wrapped items and the respective part nos are: 12mm Nut part no. 90179-18006 Tab washer " " 90215-21290 I only mention this because the modification kit & the 12mm nut are not on the normal microfiche pages but if you quote the part nos above they can be located & obtained. Re: Front Sprocket Nut & Lockwasher Part Nos - Punkstig - 10-02-16 Have you measured the nut? I've just changed my c&s, went to local yam dealer for the new nut which as far as we could work out has been superceded again but by a 10mm nut! Re: Front Sprocket Nut & Lockwasher Part Nos - darrsi - 10-02-16 (10-02-16, 12:57 PM)Punkstig link Wrote: Have you measured the nut? Why would they go 10mm from 12mm, that's just daft? Re: Front Sprocket Nut & Lockwasher Part Nos - Punkstig - 10-02-16 I know, that's why I'm asking if he's measured it- I'd assume the 12mm is still available but I didn't have the correct part number at the time and the 10mm (measured myself) is the one on the computer system) Re: Front Sprocket Nut & Lockwasher Part Nos - unfazed - 10-02-16 I have a spare nut and washer kit (90891-10124) one at home, I will measure it this evening and let you know. Re: Front Sprocket Nut & Lockwasher Part Nos - darrsi - 10-02-16 (10-02-16, 01:59 PM)unfazed link Wrote: I have a spare nut and washer kit (90891-10124) one at home, I will measure it this evening and let you know. That code is for the 12mm one, i've seen it enough times on here. Re: Front Sprocket Nut & Lockwasher Part Nos - darrsi - 10-02-16 (10-02-16, 01:17 PM)Punkstig link Wrote: I know, that's why I'm asking if he's measured it- I'd assume the 12mm is still available but I didn't have the correct part number at the time and the 10mm (measured myself) is the one on the computer system) Every little helps, as they say, i s'pose! Re: Front Sprocket Nut & Lockwasher Part Nos - Dave48 - 10-02-16 Yes -can confirm part no 90179-18006 is the 12mm size-just measured to check! Re: Front Sprocket Nut & Lockwasher Part Nos - unfazed - 10-02-16 (10-02-16, 06:37 PM)Dave48 link Wrote: Yes -can confirm part no 90179-18006 is the 12mm size-just measured to check! Just discovered that I have both: The Kit 90891-10124 with the 12mm Nut and washer in it and the Kit 90891-10124 with two separate packages in it. The part numbers packaged in two separate packages within the package are: 90215-21290 Washer 90179-18006 12mm nut See pics, both are 12mm and the only difference in the two is that the individually packaged nut in the package is shiny :eek |
