Throttle grip housing repair? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Throttle grip housing repair? (/showthread.php?tid=74920) |
Throttle grip housing repair? - Marc125030 - 09-02-16 My throttle grip lug which stops the switch rotating on the bar has snapped off, is the a diy repair or will i need to source another switch assembly? Re: Throttle grip housing repair? - b1k3rdude - 09-02-16 I would say your better off just replacing the housing, they are cheap enough. And as it happens I have one of a 2005 model (dosent have the headlight switch) if your interested. Re: Throttle grip housing repair? - markie_wales - 09-02-16 Not sure a repair will hold, get a replacement or wrap some (as best you can) colour matched gaffer tape around the bar, then refit "snug". It's usually enough to stop them spinning. Cheers Markie Re: Throttle grip housing repair? - Motopsycho87 - 10-02-16 I cut mine off and just used electrical tape around the bar to clamp it tighter so I could go renthal, works fine! Re: Throttle grip housing repair? - Marc125030 - 11-02-16 I managed to repair the old plastic housing with a cut down screw I drilled a suitable hole in the lug where it had snapped off and used a screw to create a thread then cut it to a suitable length and voila it holds perfectly |
