im not mad.. im just dissapointed. [[[SOLVED]]] - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: im not mad.. im just dissapointed. [[[SOLVED]]] (/showthread.php?tid=74820) |
im not mad.. im just dissapointed. [[[SOLVED]]] - Paulfzs - 29-01-16 due to ongoing ill health ive barely ridden my bitch but i got a call from my other half yesterday saying she had missed her train so could i come get her... hopped on the bitch for the quick 7 mile trip.. got a mile or so up the road slowed to a crawl for a car turning accelerated away hearing a bang.. instantly knew what happened.. chain decided it wanted to break..... i haven't exactly treated the chain perfectly however it wasn't that old so who knows. also managed to destroy the clutch push rod at the same time so new chain and push rod... can i call it a new bike if everything is new? because at this rate it wont be long. Re: im not mad.. im just dissapointed. - fazersharp - 29-01-16 Sorry to hear that fella Is there an fzs chain snap that does NOT result in a smashed pushrod Re: im not mad.. im just dissapointed. - Jules-C - 29-01-16 If water pump and engine casing are undamaged you were lucky! Re: im not mad.. im just dissapointed. - Deefer666 - 30-01-16 If it lets go at speed it can fry the clutch plates. Fixed a few now, normally its just a case just replacing the chain and sprockets, pushrod, & pushrod seal..... Sometimes you have to remove the output shaft seal retaining plate and straighten it. Re: im not mad.. im just dissapointed. - Paulfzs - 05-02-16 so today i decided to put my new chain on and new clutch push rod... pulled old push rod out first... shorter than i remember them being.... luckily for me it had snapped twice.. once on the tip sticking out inside the sprocket cover and once inside the engine! ![]() clutch cover off... springs out cover off just to get to the other side... managed to push it through with a screwdriver. ![]() 2 out of 3 parts.. ![]() new push rod in.. new chain on. Job jobbed! Re: im not mad.. im just dissapointed. [[[SOLVED]]] - Deefer666 - 07-02-16 Just run it up on the side stand with the front sprocket cover off and check the push rod oil seal for weepage..... Easy fix if it is leaking though
Re: im not mad.. im just dissapointed. - unfazed - 07-02-16 (29-01-16, 12:58 PM)fazersharp link Wrote: Sorry to hear that fella Yes, my sons broke at around 90mph, it only put a crack on the cover and broke a piece out of the hugger, but everything else was fine. He bought a pushrod, seal and second had cover but did not need them. I was amazed it did not do more damage. My theory is that the slower you are going when it breaks the more damage it will do, honestly officer :lol Re: im not mad.. im just dissapointed. [[[SOLVED]]] - Paulfzs - 08-02-16 (07-02-16, 07:42 PM)Deefer666 link Wrote: Just run it up on the side stand with the front sprocket cover off and check the push rod oil seal for weepage..... Easy fix if it is leaking though i did this and no leaking took it for a ride its all good however ive noticed the clutch engages much different now with a new push rod.before i had about 5 full turns out on the bar adjuster and now its most of the way in, must have been worn somewhat. Re: im not mad.. im just dissapointed. [[[SOLVED]]] - Deefer666 - 08-02-16 Good work :thumbup |
