hi all - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: Introduction (https://foc-u.co.uk/mybb/forumdisplay.php?fid=68) +--- Thread: hi all (/showthread.php?tid=74744) |
hi all - yamasaki - 21-01-16 I'm 29 from Asia, I bought my naked mod fazer400 no long ago( sorry for my poor english :b ). This bike is a little bit old, but the enginne is still good, the machine idle speed is very stable, and it start very easy. There is only 2 problems on it, first, it's cluch will slip when you try switch gears in a high rpm. The second problem is the 3rd Carbs had leaking of fuel several days ago, but it recover after I clean the carb, and I don't know when will leaking again, so I add a fuel filter to the fuel hose. This is a black bike, I take this photo at night, so it's a little bit dark. :evil [smg id=2737 type=preview align=center caption="fz400"] before that, I already have 2 suzuki and a yamaha. [smg id=2738 type=preview align=center caption="bandit250"] [smg id=2735 type=preview align=center caption="suzuki"] [smg id=2736 type=preview align=center caption="ybz125"] Re: hi all - unfazed - 21-01-16 Welcome to the fold, :thumbup what country are you in? Asia is a big place :lol That naked 400 is a rare machine, a few came like that as standard and were used for rider training in Japan with a few modifications. I have only seen one ever in the UK. There should have been a small fuel filter in the fuel line as standard. Your leak sounds like dirt in the needle valve and drain the carb float bowl normally clears it. The red Suzuki with the red cam cover is the one with variable valve timing, not to many of them over this way. That one looks very clean. What model is the black Suzuki? Re: hi all - mtread - 21-01-16 By the way, your English is very good. Better than some of ours
Re: hi all - yamasaki - 22-01-16 (21-01-16, 09:56 AM)unfazed link Wrote: Welcome to the fold, :thumbup what country are you in? Asia is a big place :lol Hi Unfazed, nice to meet you due. I'm from southern part of China, Wuzhou city. Naked Fz400 is mod with Yamaha Xjr400's panel, inicators, bar and mirrors and so on... It's very popular here, it's beacaus the weather here is warmer than Europe, it will easier to get cooling when you getting nake. it won't snow here in the winter. Yeah, the red Suzuki is GSF-250 A.K.A Bandit, and the variable valve timing we call VC, when over about 7000 rpm it works with higher camshaft to make more powerful output, it's something like HONDA's VTEC. And the black Suzuki is EN-125, I think it's only sell in China. 125cc bikes is very usual seeing here, over 95% of bikes are 125cc. Re: hi all - yamasaki - 22-01-16 (21-01-16, 10:13 PM)mtread link Wrote: By the way, your English is very good. Better than some of ours Thank you.
Re: hi all - unfazed - 22-01-16 Interesting and very effective modification and it looks very like the training model in Japan. How did you get the Speed odometer to function, did you just use the wheel sensor and speed odometer cable from the XJR400? The FZ400 and FZS600 share the same disks and wheels as the XJR400. Re: hi all - yamasaki - 22-01-16 (22-01-16, 09:09 AM)unfazed link Wrote: Interesting and very effective modification and it looks very like the training model in Japan. It was mod by it's last owner, and I don't know how he did this. All I know is that speed odometer is not precise, it go double times as fast as the really speed .
Re: hi all - mtread - 23-01-16 Sometimes you can buy reducing gears that correct speedometer readings. Might be worth investigating. Welcome to the best and most friendly owners forum on the internet. We have many owners in different countries (have a look at the members map) but I think you are our first from China, so a special welcome. Re: hi all - yamasaki - 23-01-16 Thanks mtread, It's my pleasure to join this forum. I've check out the members map, sure I'm the first one from China. The reducing gears you mention about I've never heard of it, which web I can buy one? Re: hi all - mtread - 23-01-16 One of these can be used to convert from kilometers per hour to miles per hour, so will reduce the reading by approximately half ( 0.62). http://www.ebay.co.uk/itm/SPEEDO-CABLE-KPH-TO-MPH-CONVERTER-29-99-FREEPOST-TOP-MOUNT-MECHANICAL-/331727103526?hash=item4d3c79e626:g:K4YAAMXQ3kNTghD0 You need to check whether the fittings are compatible with your bike, and you may find it cheaper in China Re: hi all - yamasaki - 25-01-16 Thank you Mtread, well that's a great mod part, I will consider about it. |
