FZ1 footpeg spring - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: FZ1 footpeg spring (/showthread.php?tid=74739) |
FZ1 footpeg spring - Streetbudgie - 20-01-16 The spring in my left hand footpeg broke tonight so the peg just flops up and down now. I had a look and it seems that the peg is held in the bracket by a non removable fixing? Any ideas if it's possible to replace the spring? Re: FZ1 footpeg spring - lew600fazer - 21-01-16 Easy , the pin is just a riveted end , disc grinder will do the job in seconds, carefully grind away the from the underside of the pinĀ , tap the pin out , get a new spring and just get a Cap head stainless Allen bolt and a lock nut. Add a drop of Locktite Blue and tighten it up until the peg will not overcome the tension of the new spring, back the nut off a tad until the spring tension is sufficient to over come the resistance so the peg will snap back. I fitted a lowering kit set of pegs to my FZ1 so I know this method will work . Lew Re: FZ1 footpeg spring - Gary - 21-01-16 I had to replace mine last year for the same reason. I bought a sping/footpeg set off Ebay and fit it handy enough. Something like this http://www.ebay.co.uk/itm/Foot-pegs-Front-Footrest-For-Yamaha-FJR1300-FZ1-FZ6-FZ6R-FZ400-xjr1200-xjr1300-/391007443653?hash=item5b09dc1ac5:g:CTgAAOSw7ThUlRFG Re: FZ1 footpeg spring - Streetbudgie - 21-01-16 Cheers for the replies guys, problem I have is that I'd have to lay out for a grinder so I'm thinking it might be easier just to replace the footpeg complete with spring. I'll see if anyone has one for sale. Re: FZ1 footpeg spring - unfazed - 21-01-16 (21-01-16, 06:58 PM)Streetbudgie link Wrote: Cheers for the replies guys, problem I have is that I'd have to lay out for a grinder so I'm thinking it might be easier just to replace the footpeg complete with spring. If you have time you could use a file :lol |
