Fzs1000 cooling fan acting weird - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Fzs1000 cooling fan acting weird (/showthread.php?tid=74737) |
Fzs1000 cooling fan acting weird - Marc125030 - 20-01-16 I've just got a 2003 Fzs1000 and the cooling fan seems to be acting peculiarly When first started the fan comes on briefly even when the engine and coolant are stone cold All other bikes I've had the fan won't turn on until 98-103'c Re: Fzs1000 cooling fan acting weird - Andy FZS - 20-01-16 Sounds normal mine does the same. I seem to think it stops when you put it in gear. But I might have imagined that bit it's been a while. .. Re: Fzs1000 cooling fan acting weird - Tmation - 20-01-16 That's normal, pick it up off the side stand and put it in gear and it will go off until up to temp, it's a protection thing. Re: Fzs1000 cooling fan acting weird - mark g - 20-01-16 Yep mine does that too :b Re: Fzs1000 cooling fan acting weird - PieEater - 22-01-16 As Tmation says this is normal and is to be expected. I contacted Yamaha to find out why they have set the bike up to do this and they said it was to prevent the radiator fan blades warping from the heat given out by the headers. |
