New fazer selector issues - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: New fazer selector issues (/showthread.php?tid=74731) |
New fazer selector issues - Neo - 19-01-16 Hi all ok so today was my maiden voyage on the fazer after collecting at the weekend, all was well it is a lovely bike with only one issue I just hope it's not a biggy. Shifting from second to third doesn't happen a lot, by this I mean the gear lever is freely working so into first no problem back to neutral no problem into second no problem out of second gear lever returns to neutral position ready for third... Raise gear lever... Nothing.... Gear lever returns back to neutral... Try third again..... Nothing (gear lever makes the travel) but no click just smooth like nothing there.. After a few more try's eventually third is found and this is how it goes on.... But the rest of the gears seem fine the problem seems from second to third only ridden it about an hour and pleased with everything else in fact more than pleased but this is tainting my overall first impression. I have read about main selector springs failing but hope it's a) nothing serious and b) not to costly, I am good with the spanners but not keen to start removing the engine and stripping gearboxes, but gutted really but don't think its cable adjustment adjustment it's done 36k Any help would be great thanks in advance Re: New fazer selector issues - b1k3rdude - 19-01-16 If it was just a case of not going into gear smooth like from neutral to 2nd then that can happen due to poorly adjusted chain, worn gear lever. Or it could be as it was in my case the clutch basket was worn enough so that the friction plates weren't releasing and causing drag. But the fact its happening from 2 to 3rd and that fact that its not selecting a gear at all means, could possibly you have either bent or very worn selector fork, or a very worn selector drum. and both of those are an engine split to fix. If its a broken return spring, I think Ive read there are outside the main crankcase and can be replaced easily enough. But the guy you swapped your DR400 for was CLEARLY fucking aware of the fault prior to selling it to you. I know this, because this has also happened to me. Take the bike back to him and demand in no uncertain terms a full refund and your DR400 back, if he give you any lip state you will then include all costs incurred to date (travel to collect the bike, etc etc) to the refund price. Re: New fazer selector issues - Neo - 19-01-16 (19-01-16, 10:41 PM)b1k3rdude link Wrote: If it was just a case of not going into gear smooth like from neutral to 2nd then that can happen due to poorly adjusted chain, worn gear lever. Or it could be as it was in my case the clutch basket was worn enough so that the friction plates weren't releasing and causing drag.I was hoping it's not that serious but reading other issues on here it certainly looks like it may be this il will have a fettle tomorrow and try it again but can't see it just going away there's defiantly an issue there despite previous owner denying any issue will keep you all posted ... Thanks so far Re: New fazer selector issues - nickodemon - 19-01-16 It sound like the selector fork/drum is damaged. I don't think it's the return spring,as that would affect all gears.
Re: New fazer selector issues - b1k3rdude - 19-01-16 As you only had a few posts, I went back through and saw you did a bike swap. I know its a pain when shit like this happen, even more so because a bike swap was involved. But when it happened to me I got the police involved, if the gearbox had locked up when I was on the motorway I would have been a jam stain. If it is just the return spring, then according to the following links its easy to replace (it just under the shifter cover on the l/h side) and prove if its that or something more serious - - http://www.yamahafz1oa.com/forum/showthread.php?s=&threadid=11875&highlight=shifter+spring Tension Spring Part# 90506-14002-00 [update] Ninja'd buy ND, It only takes a 10-15mins to remove the shifter cover and check the detent (return) spring, if that's in place that its "return the bike and demand your DRZ400 and what ever cash you paid back. At the end of the day you could have and there is still the risk of having a serious accident due to the gearbox locking up. Re: New fazer selector issues - Neo - 19-01-16 I didn't do a deal with this man I bought the bike it was the one on here for sale by wooderson in the for sale section stupidly I didn't ride it before I forked over the money but will ride it again tomorrow just to be sure and check chain line and adjustment although I did look briefly today and it looked fine to me Re: New fazer selector issues - b1k3rdude - 19-01-16 (19-01-16, 11:13 PM)Neo link Wrote:
Re: New fazer selector issues - Neo - 19-01-16 (19-01-16, 11:13 PM)Neo link Wrote: I didn't do a deal with this man I bought the bike it was the one on here for sale by wooderson in the for sale section stupidly I didn't ride it before I forked over the money but will ride it again tomorrow just to be sure and check chain line and adjustment although I did look briefly today and it looked fine to meAs in I didn't swap a bike I just bought it :'( Re: New fazer selector issues - Neo - 19-01-16 (19-01-16, 11:34 PM)b1k3rdude link Wrote: [quote author=Neo link=topic=19167.msg221962#msg221962 date=1453241589]
Thanks for your help Re: New fazer selector issues - b1k3rdude - 19-01-16 Was it a private sale or from a business..? Im currently googling consumer rights and private sales. I am fairly certain that because the fault is serious enough that it could have potentially killed you, that you unequivocally entitled to a full refund and the police need to be made aware. Another thing that springs to mind is the bike is not fit for purpose, due to a faulty gearbox. Also quoting the Consumer act - "The vehicle must match the seller’s description, be roadworthy" Clearly it dosen't, as the seller never mentioned the gearbox issue and as your not a trained mechanic you cannot be expected to spot such a serious fault, even less so as it dosen't happen all the time. So more info that seem relevant - - http://www.which.co.uk/consumer-rights/problem/the-second-hand--car-i-bought-has-a-problem-what-are-my-rights Re: New fazer selector issues - Neo - 20-01-16 (19-01-16, 11:40 PM)b1k3rdude link Wrote: Was it a private sale or from a business..? Im currently googling consumer rights and private sales. I am fairly certain that because the fault is serious enough that it could have potentially killed you, that you unequivocally entitled to a full refund and the police need to be made aware.Hi it was a private sale, the bloke seemed so genuine, when I questioned him yesterday in a text message he said he had never noticed it and he said it could be where he changed the levers to pazzo recently, I said it's not that or clutch related as all other gears and clutch bite is fine, I'll re try the bike later although I doubt it will have self healed over night, then I'll re contact the seller if there is definitely an issue and see where to go from there. Re: New fazer selector issues - limax2 - 20-01-16 Might be worth trying to select the gears by hand with the bike on the centre stand and turning the back wheel by hand, with the engine stopped of course. When I say turning the back wheel I only mean rocking it backward and forward to move the gears so they can engage when you get full pedal movement, not trying to turn the engine. If third engages engages every time that way then you might need to adjust the gear lever position to suit your own foot position. It's a long shot but if the seller is telling the truth it might sort it for you. I have found just wearing some different boots can affect how the gear change feels. Worth a try and if it still fails to engage gear you can demonstrate it to the seller. Re: New fazer selector issues - Neo - 20-01-16 (20-01-16, 10:48 AM)limax2 link Wrote: Might be worth trying to select the gears by hand with the bike on the centre stand and turning the back wheel by hand, with the engine stopped of course.agreed I tried this yesterday and it goes in absolutely fine will try today with flip flops briefly so I get full feel I really think the seller is genuine hence the doubt in myself I hope it's me as I LOVE the bike Re: New fazer selector issues - Neo - 20-01-16 UPDATE ... Just been out for an hour with trainers on eeek... But I could feel the heat change better and all gears now work fine (embarrassed) not sure why it did it yesterday... Must be boots in a certain position insipid I did fettle with the chain and linkages and whilst sometimes the gear lever seems stiff coming back down through the box it's bearable so looks like it was operator error in this case which is good as I love the bike it's brill around town easy to go to 20 in top then pull away and nice and balanced plenty of poke God knows why you'd want more !! I'll keep you all posted with progression but all seems well so thanks for all your advice on here you all top people Re: New fazer selector issues - Neo - 20-01-16 (20-01-16, 03:18 PM)Neo link Wrote: UPDATE ... Just been out for an hour with trainers on eeek... But I could feel the heat change better and all gears now work fine (embarrassed) not sure why it did it yesterday... Must be boots in a certain position insipid I did fettle with the chain and linkages and whilst sometimes the gear lever seems stiff coming back down through the box it's bearable so looks like it was operator error in this case which is good as I love the bike it's brill around town easy to go to 20 in top then pull away and nice and balanced plenty of poke God knows why you'd want more !! I'll keep you all posted with progression but all seems well so thanks for all your advice on here you all top peopleedit.. Gear changer not heat changer .... Apple typo grrrr Re: New fazer selector issues - tomsmith051 - 20-01-16 Glad to see it wasn't a major problem I'm already spending money on mine, needs the fork seals changing but I've done it before on other bikes and there is a decent guide on the older Fazer forum, the yuku one, so I should be good to do this at the weekend.Hope to see your around. Re: New fazer selector issues - Neo - 20-01-16 Cheers Tom I could have popped in earlier I just went to Bognor on the "shake down" run with me trainers on as mentioned, yours looks nice mate my number is 07414140141 if you want to meet up for a ride out?? Did you get yours locally? People on here say there faster in blue Re: New fazer selector issues - Neo - 20-01-16 Ps good luck with the fork seals ha e you a workshop manual? Re: New fazer selector issues - Neo - 20-01-16 Carl salter has various manuals you can download Re: New fazer selector issues - tomsmith051 - 20-01-16 I didn't know about that website, I'll bookmark that one. Thanks but like I said I found a pretty comprehensive guide here: http://fazerowners.yuku.com/topic/23188/HOWTO-Forks-Seals-Bushes-and-Oil#.Vp9UF1OLRUc Looked through it and it all looks right, plus since I've done it before shouldn't be a problem. I'll shoot you a message and we'll meet up sometime, be good to have a blast when I can afford the fuel xD It's nippy compared to the DRZ, I'll give it that. Comfy as well. |
