newbie to forum hi to all. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: Introduction (https://foc-u.co.uk/mybb/forumdisplay.php?fid=68) +--- Thread: newbie to forum hi to all. (/showthread.php?tid=74690) |
newbie to forum hi to all. - gedbedhead - 12-01-16 bought a 98 fazer today. will tidy it up for the summer. so will be on this site quite a bit. thanks ged. PICTURES TO FOLLOW Re: newbie to forum hi to all. - Cellarman - 12-01-16 Welcome aboard Re: newbie to forum hi to all. - sinto607276 - 13-01-16 (12-01-16, 09:00 PM)gedbedhead link Wrote: bought a 98 fazer today. will tidy it up for the summer.Welcome to the madhouse :b :useless Re: newbie to forum hi to all. - eddie - 14-01-16 Is this you 1st fazer If so points to watch out for...brakes don't like salt the pistons can seize..check an clean if necessary at least once a month, down pipes are mild steel so you may need to paint with high temp paint to ward off the dreaded rust, front sprocket has been known to come loose..check with previous owner if modified nut fitted or have dealer check, modified is peanuts also always fit new tab washer if changing front sprocket, |
