Windscreen bolts - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Windscreen bolts (/showthread.php?tid=74651) |
Windscreen bolts - msewelly - 08-01-16 Trying to change my windscreen over, the bolts just seem to spin, two have come out with ease but the others just spin, they are still holding the windscreen in. Any suggestions Re: Windscreen bolts - RMT1983 - 08-01-16 inside the rubber on the back of the nose cone there are small nuts, either 6mm or 8mm. with a blade or snips remove the rubber from the old fixings and use a spanner or socket on the nuts to hold it whilst you undue the bolt............. Hope that all makes sense Re: Windscreen bolts - msewelly - 08-01-16 Thanks for the reply, under the rubber it appears its round metal ie no bolts. I've tried holding them in place while turning the bolt but it just spins the same Re: Windscreen bolts - RMT1983 - 08-01-16 Mole grips it is then!!! |
