Very small hole in can.. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Very small hole in can.. (/showthread.php?tid=74596) |
Very small hole in can.. - infiniteloop - 31-12-15 Found a very small hole in my exhaust can (2-3mm)..what's the best method of repair..? Heard a few options from pop rivets to self tapping screw, but I'm thinking it could be repaired by brazing..? Any advice much appreciated Re: Very small hole in can.. - darrsi - 31-12-15 Where is it though? Re: Very small hole in can.. - Deefer666 - 31-12-15 if its underneath at the end where the link pipe joins it. Its supposed to be there Re: Very small hole in can.. - Gnasher - 31-12-15 :agree Yep it's a water drain hole. Re: Very small hole in can.. - fazersharp - 31-12-15 Yep and I think there should be 2. It may look like a rust hole because it will have staining around it as the condenced water leaks out- give it a clean and you should see that it is a perfect clean round hole Re: Very small hole in can.. - infiniteloop - 31-12-15 It's right on the middle on the underside of the can..only noticed it when i spotted exhaust fumes coming from it on a cold morning Re: Very small hole in can.. - fazersharp - 31-12-15 (31-12-15, 07:52 PM)infiniteloop link Wrote: It's right on the middle on the underside of the can..only noticed it when i spotted exhaust fumes coming from it on a cold morningright on the end next to the link pipe ? Get on your back and have a closer look right under and you should see another one Have you noticed that sometimes when you park up after a run that you see some wet drops under your end can- thats the condensate coming out of the hole Re: Very small hole in can.. - infiniteloop - 31-12-15 No..not at one side or the other..right in the middle Re: Very small hole in can.. - fazersharp - 31-12-15 Pictures please A few months ago there was the exact same discussion but I can not find it have a search Re: Very small hole in can.. - YamFazFan - 01-01-16 (31-12-15, 09:03 PM)fazersharp link Wrote: Pictures please It's here... http://foc-u.co.uk/index.php/topic,15938.0.html Re: Very small hole in can.. - fazersharp - 01-01-16 (01-01-16, 01:22 PM)YamFazFan link Wrote: [quote author=fazersharp link=topic=19031.msg220451#msg220451 date=1451592199] It's here... http://foc-u.co.uk/index.php/topic,15938.0.html [/quote] Well done. I suppose that we are jumping the gun in assuming that the hole is this bit being stainless steel the outside can does not rust does it Re: Very small hole in can.. - YamFazFan - 01-01-16 It sounds to me like it's one of the drain holes. There's a couple of close up pic's of them in the thread link to compare with. Re: Very small hole in can.. - darrsi - 01-01-16 . :useless Re: Very small hole in can.. - infiniteloop - 01-01-16 Many thanks for the replies & link..I'll try to get a closer look at my exhaust & get a pic. |
