power supply - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: power supply (/showthread.php?tid=74497) |
power supply - devilsyam - 15-12-15 I need to source a power point take of which is switched on/off by ignition on both gen1 and gen2 anyone help Re: power supply - characticus - 15-12-15 Alarm connector under seat on Gen1? Re: power supply - keithfzs1000 - 15-12-15 http://foc-u.co.uk/index.php?topic=9917.msg102172;topicseen#new Gen 1 Re: power supply - DekF - 15-12-15 (15-12-15, 06:04 PM)devilsyam link Wrote: I need to source a power point take of which is switched on/off by ignition on both gen1 and gen2 anyone help Luke, is it to power a relay or a directly connected heavy load. A relay only draws milliamps but a heavy load could be upto 15 amps. If it's a relay the rear light circuit is sufficient but if not you may need a relay anyway to switch the load. |
