possible leaking carb rubbers.... fix? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: possible leaking carb rubbers.... fix? (/showthread.php?tid=74425) |
possible leaking carb rubbers.... fix? - Paulfzs - 04-12-15 title says it all, any easy fix for cracked carb rubbers.. Some sort of clear spray? I looked into silicone spray but appears to just be a lubricant version (is this any good on chains btw?) Re: possible leaking carb rubbers.... fix? - darrsi - 04-12-15 New ones. :lol Re: possible leaking carb rubbers.... fix? - Paulfzs - 04-12-15 (04-12-15, 02:19 PM)darrsi link Wrote: New ones. :lol ill pm my address right now
Re: possible leaking carb rubbers.... fix? - fazersharp - 04-12-15 They may not be as bad as you think - they have to look very bad before that actually leak. A fix is silicone sealant used for bathrooms,windows, building you can get it in black smear it in your crack :eek . also self amalgamating tape ontop of said silicone when dry or just the tape on its own. I think that the problem mostly affects the outside ones (sun damage) Re: possible leaking carb rubbers.... fix? - YamFazFan - 05-12-15 (04-12-15, 01:42 PM)Paulfzs link Wrote: I looked into silicone spray but appears to just be a lubricant version (is this any good on chains btw?) I don't think it would be suitable for chains. I've been using this chain lube recently and it mentions it being silicone free on the can... Re: possible leaking carb rubbers.... fix? - His Dudeness - 05-12-15 Silicone helps a bit but it probably has more of a placebo effect than any real improvement. If they're properly cracked bin them. Ebay has reasonably priced ones. Re: possible leaking carb rubbers.... fix? - sc0ttie - 15-12-15 I got some high temp black silicone from ebay, I just filled in the cracks, not sure if mine were leaking but I did it in the hope that it might slow down the deterioration of the carb rubbers. That was 6 months ago. Re: possible leaking carb rubbers.... fix? - unfazed - 15-12-15 (04-12-15, 01:42 PM)Paulfzs link Wrote: title says it all, any easy fix for cracked carb rubbers.. Easiest permanent fix is replace them with a new set. :eek Around £80 from M&P
Re: possible leaking carb rubbers.... fix? - fazersharp - 17-12-15 (15-12-15, 02:08 PM)unfazed link Wrote: [quote author=Paulfzs link=topic=18860.msg217959#msg217959 date=1449232952] Easiest permanent fix is replace them with a new set. :eek Around £80 from M&P [/quote] This is what you need http://www.screwfix.com/p/no-nonsense-general-purpose-silicone-sealant-black-310ml/2279h#product_additional_details_container I dont think its the cost so much (is it ? ) but more like the faf in changing them, from what I hear the new ones are a pig to get back on Re: possible leaking carb rubbers.... fix? - Frosties - 17-12-15 (15-12-15, 01:40 PM)sc0ttie link Wrote: I got some high temp black silicone from ebay, I just filled in the cracks, not sure if mine were leaking but I did it in the hope that it might slow down the deterioration of the carb rubbers. That was 6 months ago. Basically done the same here for the same reasons. Done over a year ago and still looking/running good. Re: possible leaking carb rubbers.... fix? - unfazed - 17-12-15 (17-12-15, 11:16 AM)fazersharp link Wrote: [quote author=unfazed link=topic=18860.msg218969#msg218969 date=1450184939]Easiest permanent fix is replace them with a new set. :eek Around £80 from M&P [/quote] This is what you need http://www.screwfix.com/p/no-nonsense-general-purpose-silicone-sealant-black-310ml/2279h#product_additional_details_container I dont think its the cost so much (is it ? ) but more like the faf in changing them, from what I hear the new ones are a pig to get back on [/quote] Not a big problem just soak a clean lint free rag in WD40 and wipe it around the ends of the carbs and the inners of the manifold rubbers. Like sex they slide right in :lol Make sure the clamps are loose. A good guide is to have the screw end level with the end of the nut. |
