Ivanised Carbs........................ - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Ivanised Carbs........................ (/showthread.php?tid=74408) |
Ivanised Carbs........................ - RMT1983 - 30-11-15 Good Evening guys! Ive been fortunate enough to lay my hands on a cheap pair of carbs and with everything else that was on the bike I reckon they may be Ivanised............. Is there any clear indicators in the carbs that I could be looking for? Fingers crossed these are what I hope they are!!! Re: Ivanised Carbs........................ - Falcon 269 - 30-11-15 Raise the throttle plates and check the pilot circuit bypass holes. If one or two have been enlarged, the carbs are 'Ivanised'. To find out which kit is installed, remove a float bowl and check the main jet. If it says 127.5 it's a Full Monty job. If the main is 122.5, that's a Slip On kit. Re: Ivanised Carbs........................ - nickodemon - 01-12-15 Check if the springs have been clipped and also check if the needles are tapered. The standard ones are almost straight. Re: Ivanised Carbs........................ - RMT1983 - 04-12-15 what do you reckon mike? Re: Ivanised Carbs........................ - Falcon 269 - 04-12-15 Definitely Ivan's Slip On kit. On a pre-03 late model onwards set of carbs. Re: Ivanised Carbs........................ - RMT1983 - 04-12-15 What's needed to turn them into full monty carbs? is it just a change of main jet? or is there more that needs doing to them? I've got some spare rubbers and airbox so that isn't a problem, just wondered if the full monty kit could be done easily? Re: Ivanised Carbs........................ - Falcon 269 - 05-12-15 First, you need to mod the airbox lid and the intake stubs: http://www.yamahafz1oa.com/forum/showthread.php?t=17064&highlight=Ivans+air+box+mod http://www.yamahafz1oa.com/forum/showthread.php?t=47373&highlight=intake+boot+mods With the airbox lid mod, ignore the first photo shown as it's wrong. Post #16 shows the correct version. You will also need a performance air filter (Pipercross are good) and Ivan's MB jet kit. It has different needles and main jets. This isn't just a jet swap job. ![]() Re: Ivanised Carbs........................ - nickodemon - 06-12-15 Are the carbs for sale? |
