Engineers - what drill bits - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Engineers - what drill bits (/showthread.php?tid=74377) |
Engineers - what drill bits - locksmith - 25-11-15 Need recommendations for HSS drill bits, just regular sizes ie. 2 - 12mm Used Rawlplug for many years but they've obviously changed something as they blunt and snap real easily nowdays. So what brands are good? Re: Engineers - what drill bits - davey boy - 25-11-15 I use Dormer at work. They work well on exotic stainless steels so should be good for you Re: Engineers - what drill bits - mickvp - 25-11-15 we use sandvik, seco, and walter in work. sandvik and walter are ok (I think they are the same company now), but seco are cheap sh*t. I should point out that most of the tools we use in an industrial engineering environment are crown-loc drills now (the shaft is permanent and you just replace the tip of the drill). Re: Engineers - what drill bits - Frosties - 25-11-15 I've sat with these for a while now - do the job for me every time http://www.amazon.co.uk/Piranha-1-10mm-Metal-Bullet-Pieces/dp/B007FUF9F4 Re: Engineers - what drill bits - celticdog - 25-11-15 (25-11-15, 10:53 AM)davey boy link Wrote: I use Dormer at work. They work well on exotic stainless steels so should be good for you +1 for Dormer, long live the Jobber! Of course it all depends on what you're drilling. Re: Engineers - what drill bits - locksmith - 25-11-15 Dormer thats a blast from the past, used to use them years ago and I can get them trade so I'll give them a try. I use the bits every day on various lock fitting/drilling duties Re: Engineers - what drill bits - lew600fazer - 26-11-15 A lot of the time it is not the drill that is the problem but the operator. Depending on what you are drilling it is down drill head speed, cooling fluid being used, or lubricant at the drill head. Most drill failures are down to not letting the bit do it's job, as in drill!!, not trying to punch the hole through. Re: Engineers - what drill bits - slimwilly - 26-11-15 Yes. True. S low head speed is a must. Re: Engineers - what drill bits - johnakay - 26-11-15 on harden steel you need to keep the drill sharp and correct speed as well as lube, I use Rocol lube. stinks when hot but does the job. http://www.ebay.co.uk/itm/Rocol-Sapphire-Precision-Lube-400ml-34341-ROC34341-/272035358976?hash=item3f56922900:g:GWsAAOSwYHxWOIfo Re: Engineers - what drill bits - locksmith - 27-11-15 So is holding the battery drill like a gun slinger not the way to go? :lol Re: Engineers - what drill bits - Frosties - 27-11-15 (27-11-15, 12:54 PM)locksmith link Wrote: So is holding the battery drill like a gun slinger not the way to go? :lol Nope! Nor is it cool to pretend you are Robocop :lol Re: Engineers - what drill bits - bobdog - 27-11-15 if your drilling stainless steel you can get drill bits for drilling stainless steel, not much more expensive realy. |
