Master cylinder screws. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Master cylinder screws. (/showthread.php?tid=74332) |
Master cylinder screws. - CaptainCazador - 17-11-15 I know master cylinder screws like to round off so this time around I wish to have replacements to hand rather than fighting to get minced ones back in until I can obtain replacements. I have never bled the Fazers brakes but from looking at the screws I think they are M4 X 20mm can anyone confirm this before I place my order? Thanks. Re: Master cylinder screws. - darrsi - 17-11-15 https://www.yamahamotorcyclespares.co.uk/product/yamaha/987070401200/screw,%20flat?uid=0 http://www.thumpertalk.com/topic/990579-front-mastercylinder-reservoir-cap-screws/ Re: Master cylinder screws. - Jamieg285 - 18-11-15 I can't confirm the size, but would agree with your guess. I took my originals into the local bolt suppliers and they were able to match them easily, so they aren't anything odd. I switched to ones that need an allen key rather than screw driver, less likely to get chewed up. Re: Master cylinder screws. - joebloggs - 18-11-15 (18-11-15, 02:41 PM)Jamieg285 link Wrote: I can't confirm the size, but would agree with your guess.+1 on the allen key, stainless with a little copperslip will make sure they come out next time Re: Master cylinder screws. - Paulfzs - 18-11-15 just weld it on :rollin :rollin :rollin :rollin :rollin :rollin Re: Master cylinder screws. - joebloggs - 18-11-15 (18-11-15, 02:53 PM)Paulfzs link Wrote: just weld it on :rollin :rollin :rollin :rollin :rollin :rollin Re: Master cylinder screws. - Paulfzs - 18-11-15 (18-11-15, 04:13 PM)joebloggs link Wrote: [quote author=Paulfzs link=topic=18766.msg216497#msg216497 date=1447854798][/quote] Not to dig at him too much, but this is his handy work on an old sprocket ![]()
Re: Master cylinder screws. - darrsi - 18-11-15 I take it nobody bothered opening the 2nd link I posted above, the one with the same part number as in the 1st link, and the size? I'm wasted on here. :'( Re: Master cylinder screws. - Paulfzs - 18-11-15 (18-11-15, 06:16 PM)darrsi link Wrote: I take it nobody bothered opening the 2nd link I posted above, the one with the same part number as in the 1st link, and the size? i see no link, only code that links to a different dimension
Re: Master cylinder screws. - darrsi - 19-11-15 (18-11-15, 09:02 PM)Paulfzs link Wrote: [quote author=darrsi link=topic=18766.msg216516#msg216516 date=1447866976] i see no link, only code that links to a different dimension [/quote] You been watching Quantum Leap perchance? :lol Re: Master cylinder screws. - StuSid - 22-11-15 I bought these for mine as the previous owner had wrecked one of the screws took me ages to get it out. http://www.ebay.co.uk/itm/151432270518?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT Re: Master cylinder screws. - Deefer666 - 22-11-15 If you get some "Go Through" screwdrivers and tap the top of the screw driver with a nylon mallet it shocks the corrosion holding the screw in, it also seats the screwdriver tip into the recess more and 9 times out of 10 the screw will come undone. It also helps to know the difference between a Pozi-drive screw and a Phillips screw and use the appropriate screwdriver so you don't mash up the recess in the first place. Re: Master cylinder screws. - Flak - 22-11-15 (22-11-15, 04:02 PM)Deefer666 link Wrote: If you get some "Go Through" screwdrivers and tap the top of the screw driver with a nylon mallet it shocks the corrosion holding the screw in, it also seats the screwdriver tip into the recess more and 9 times out of 10 the screw will come undone. They're probably neither of those but JIS. Re: Master cylinder screws. - Deefer666 - 23-11-15 JIS = Standard Philips head screws, the problem arises when people do not know the difference and use a Pozi-Drive screwdriver in them. Which will of course chew the recess up. |
