Parts compatability with 600 - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 400 and other models (https://foc-u.co.uk/mybb/forumdisplay.php?fid=79) +--- Thread: Parts compatability with 600 (/showthread.php?tid=74303) |
Parts compatability with 600 - bolanjames - 14-11-15 Hi everyone. Could someone let me know if the fuel tanks are the same on both bikes. Are they interchangable and also the body work plastics. Thanks. Re: Parts compatability with 600 - RMT1983 - 14-11-15 yes they are. the only different I found was that the rear seat fairing for the 600 has holes for the pillion grab handles and the 400 doesnt Re: Parts compatability with 600 - bolanjames - 15-11-15 Thanks for that. Should have asked this as well but are the clocks a straight swap with the 600 to give mph reading or is there some other stuff to do as well. Re: Parts compatability with 600 - His Dudeness - 15-11-15 The tanks may be the same but the 400 has a vacuum tap under the tank whereas I think the 600 has an off on fuel tap. I think it should still work but you might want to swap over the vacuum tap. I could be wrong though I haven't seen a 600 tank. The clocks I'm not sure about but I'd be surprised if it was a straight swap Re: Parts compatability with 600 - Deefer666 - 16-11-15 I thought most parts, apart from the obvious where the same. I have dropped an entire 600 clutch basket into a 400 and it fitted. The 400 clutch is pathetic! |
