cleaning front brake disc bobbins / rivets? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: cleaning front brake disc bobbins / rivets? (/showthread.php?tid=74215) Pages:
cleaning front brake disc bobbins / rivets? - Bretty - 03-11-15 My front brake has a slight pulse at low speeds. The surface has no high spots (measured with a vernier while rotating the front wheel). As I've read that the disc is semi-floating, I thought I might be able to remedy the problem by cleaning the disc bobbins/rivets to allow the disc to float. At the moment everything is solid and I'm assuming the disc has a wobble. I've seen videos on youtube of people cleaning the bobbins by putting a nut and bolt through the hole and using a socket to rotate them while giving a good application of brake cleaner. But mine don't have a hole in the middle?! Has anyone done any cleaning of the rivets? Is there another way to rotate them or is it a spray and toothbrush job? Wot you reckon? Re: cleaning front brake disc bobbins / rivets? - darrsi - 03-11-15 Personally from experience, it won't make the slightest bit of difference at all. Re: cleaning front brake disc bobbins / rivets? - darrsi - 03-11-15 As a starting point I would be looking more towards making sure the pistons are moving okay and not seized up anywhere. Re: cleaning front brake disc bobbins / rivets? - joebloggs - 03-11-15 (03-11-15, 02:59 PM)darrsi link Wrote: As a starting point I would be looking more towards making sure the pistons are moving okay and not seized up anywhere. +1 on the calipers No runout on the disc so look at them 1st Re: cleaning front brake disc bobbins / rivets? - stevierst - 03-11-15 Cleaning the bobbins should make a bit of difference, it has done on a couple of mine in the past when I had pulsing brakes. Cleaning the calipers is always recommended, but sticky pistons are not a cause of pulsing at low speed. You can tell if they need it if the disk is solid and doesn't move at all, or if there is a grating noise with minimal lateral movement of the disk. Nut and bolt through the bobbin with loads of brake cleaner when you start turning. Keep going until the bobbin is free, but don't be tempted to use a drill like I've seen in the past. Patience and cleaner is the key! Re: cleaning front brake disc bobbins / rivets? - darrsi - 03-11-15 Hotspots on a disc can cause a grabbing effect at low speed, which won't really show up with a vernier. Normally caused by holding a brake on at traffic lights with a hot disc so it leaves a pad deposit on the disc. Some are very obvious to the eye but not all of them. What brake lines do you have on the bike, are they the original type, or new braided? Old style lines can get tired then have bulges in the line causing juddering sensation. I was unfortunate enough to have faulty braided lines which cost me a lot of time, money and patience, before discovering what was wrong by default, because the brake lines were the only thing I hadn't changed on the whole front end of my bike. Was the same feeling as a warped disc, but because they were braided I never suspected them whatsoever and in hindsight i stupidly overlooked them. :'( Re: cleaning front brake disc bobbins / rivets? - joebloggs - 03-11-15 Have you tried oiling your pads, that should take care of any pulsing at low speeds, be sure to give a real good tug on the lever next time you want to stop :eek :eek :eek Re: cleaning front brake disc bobbins / rivets? - Timbollew - 03-11-15 Please for the love of sweet baby Jesus ignore joebloggs's comment! Re: cleaning front brake disc bobbins / rivets? - darrsi - 03-11-15 (03-11-15, 07:20 PM)joebloggs link Wrote: Have you tried oiling your pads, that should take care of any pulsing at low speeds, be sure to give a real good tug on the lever next time you want to stop :eek :eek :eek Why would you say that? :rolleyes Re: cleaning front brake disc bobbins / rivets? - Val - 03-11-15 (03-11-15, 01:37 PM)Bretty link Wrote: My front brake has a slight pulse at low speeds. The surface has no high spots (measured with a vernier while rotating the front wheel). As I've read that the disc is semi-floating, I thought I might be able to remedy the problem by cleaning the disc bobbins/rivets to allow the disc to float. At the moment everything is solid and I'm assuming the disc has a wobble. Do not beleive everything you see on the internet :lol As you have stated your disc is semi-floating and the bobbins does not have a gap and does not need cleaning by design. The problem is somewhere else like the disc or the lines... (03-11-15, 07:20 PM)joebloggs link Wrote: Have you tried oiling your pads, that should take care of any pulsing at low speeds, be sure to give a real good tug on the lever next time you want to stop :eek :eek :eek That was supposed to be a joke...but its not funny related to brakes, someone may take it seriously. Just to be clear do not do that
Re: cleaning front brake disc bobbins / rivets? - Bretty - 04-11-15 Oil the discs, haha! :rollin Well I have 2 cans of brake cleaner and the plan is: 1. Clean pistons and pads with toothbrush and brake cleaner. 2. Brillopad / wirewool disc with brake cleaner 3. Toothbrush and brake cleaner on rivets. I don't understand why the brake lines would create a pulse. Mine are all standard. Everything actually runs freely and the pads do retract and don't drag. But a clean won't hurt. With a fixed caliper you have to have some movement somewhere to allow for the slight warp of a hot disc. Anyway, it needs sorting because a couple of times I've locked the front wheel under heavy braking when it shouldn't have. I'll let you know how I get on.... Re: cleaning front brake disc bobbins / rivets? - midden - 04-11-15 Ive started getting the same once the bike has slowed to a near stop. Re: cleaning front brake disc bobbins / rivets? - darrsi - 04-11-15 (04-11-15, 12:37 AM)Bretty link Wrote: Oil the discs, haha! :rollin Brake lines can break down with age and get weak spots, so when you brake the pressure can cause a bulge in the line. It will then give a pulsing/throbbing feeling when braking, which can be mistaken for a warped disc. You wanna buy yourself a small pot of Red Rubber Grease to put on the exposed parts of your cleaned pistons, it will help keep the crap and rust at bay. And get the wire wool on the pad pins, and make sure there's no indents on them either, stopping the pads from moving freely sideways. As for the "oil the discs" comment, yes i realise that's a (bad) joke, but you have to remember these posts stay on here for a long time, or get found in a search, and it only takes a complete newbie to only read that part and believe it then.....well, you can only imagine the rest. Saw it on another forum years back and some youngster listened to some joker and cleaned all his brakes with WD40 on advice. That didn't end well. Re: cleaning front brake disc bobbins / rivets? - darrsi - 04-11-15 (04-11-15, 12:56 AM)midden link Wrote: Ive started getting the same once the bike has slowed to a near stop. I thought yours was caused more by leaving the disc lock on? :lol :pokefun Re: cleaning front brake disc bobbins / rivets? - joebloggs - 04-11-15 Disclaimer........ If your dumb enough to oil/wd40 your brakes them please don't come crying to me................. Re: cleaning front brake disc bobbins / rivets? - bigsteve - 04-11-15 this might be worth checking out for bobbins https://www.youtube.com/watch?v=1qoPqN2GBdw Re: cleaning front brake disc bobbins / rivets? - Bretty - 04-11-15 (04-11-15, 08:16 PM)bigsteve link Wrote: this might be worth checking out for bobbins That's where I got my inspiration! BUT my bobbins don't have holes through them!! They are like rivets!! Isn't everyone's Fazer like that? Re: cleaning front brake disc bobbins / rivets? - Val - 04-11-15 (04-11-15, 08:16 PM)bigsteve link Wrote: this might be worth checking out for bobbins Delboy has the best garage videos and I watch him a lot. IMO he is wrong on that one. Floating discs are the only ones that should be cleaned, semi-floating by design does not need cleaning. Do you think Yamaha would have missed such important brake maintainance procedure if it was required? The point is rivets has high pressure by design and they are not meant to be rotated, consider yourself lucky there are not holes there :lol See this discussion with Delboy here: http://www.bikerforum.co.uk/topic/30502-cleaning-brake-discs/page__st__20 Re: cleaning front brake disc bobbins / rivets? - darrsi - 04-11-15 (04-11-15, 10:13 PM)Val link Wrote: [quote author=bigsteve link=topic=18649.msg215033#msg215033 date=1446664582] Delboy has the best garage videos and I watch him a lot. IMO he is wrong on that one. Floating discs are the only ones that should be cleaned, semi-floating by design does not need cleaning. Do you think Yamaha would have missed such important brake maintainance procedure if it was required? The point is rivets has high pressure by design and they are not meant to be rotated, consider yourself lucky there are not holes there :lol See this discussion with Delboy here: http://www.bikerforum.co.uk/topic/30502-cleaning-brake-discs/page__st__20 [/quote] Gotta agree with you on this one, plus I tried it myself before and it did nothing! Re: cleaning front brake disc bobbins / rivets? - Bretty - 04-11-15 Well I don't know what qualifications any of these people have (I read that long discussion on the other forum)... ![]() But anyway the calliper is gonna get a right good cleaning... and the discs - just a non-vigorous toothbrush clean of the rivets and a scrub of the braking surface.
