Side stand engine cut out switch in more detail? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Side stand engine cut out switch in more detail? (/showthread.php?tid=74170) |
Side stand engine cut out switch in more detail? - SteveMc278 - 27-10-15 Tricky one to explain this, but here goes: Should the side stand engine cut out switch - 1)stop the engine when bike's in gear (with clutch pulled in) when the side stand's down? ORĀ 2)should the engine cut itself out at the moment when the clutch is let out - as you ride off (when the side stand's down)? Re: Side stand engine cut out switch in more detail? - fazersharp - 27-10-15 with stand down the cut out comes when you put it in gear-- clutch is already in to put it in gear - all ok until you go from neutral So your optionĀ (1) is correct Re: Side stand engine cut out switch in more detail? - BBROWN1664 - 28-10-15 1) Re: Side stand engine cut out switch in more detail? - Ferg - 28-10-15 Agree 1) Re: Side stand engine cut out switch in more detail? - limax2 - 29-10-15 I check the action now and again, accidentally !!! Re: Side stand engine cut out switch in more detail? - StuSid - 29-10-15 I agree with everyone else number 1 is right, however my Fazer wouldnt even start in neutral when the side stand was down so i disconnected the cut off switch and got my Dad (auto electrician and mechanic) to use it as an immobiliser for my alarm. |
