New gen 1 has 7000rpm fault code......................... - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: New gen 1 has 7000rpm fault code......................... (/showthread.php?tid=74129) |
New gen 1 has 7000rpm fault code......................... - nickodemon - 22-10-15 I got the new bike yesterday and the tacho was showing the 7000 exup fault... I stripped and cleaned the valve and then lubed with ceramic grease, it feels like it rotates absolutely fine. I then started the bike and it is again showing the 7000 rpm exup valve fault.... Re: New gen 1 has 7000rpm fault code......................... - Tmation - 23-10-15 Knackered servo or cables then. disconnect cables and see if it goes away Re: New gen 1 has 7000rpm fault code......................... - unfazed - 23-10-15 Either the EXUP motor gone or stiff cables. Check the cable are free running and there is slack at the valve first. (Wemoto do a set of cables for £50) If cables are fine change the Exup motor Re: New gen 1 has 7000rpm fault code......................... - Red Ceri - 23-10-15 If your cables need adjusting and all you did was clean and grease the valve and put the cables back where they were without re-setting them you would still get the 7k fault code, adjust the cables as per Pat's page here - http://www.cartestsoftware.com/fz1/exupmaintenance.html Then re-check for fault code. Re: New gen 1 has 7000rpm fault code......................... - nickodemon - 23-10-15 I noticed that it returns to the closed position slowly, so i will take a look at the cables Re: New gen 1 has 7000rpm fault code......................... - nickodemon - 23-10-15 Cables were slack, so adjusted and all seems well :thumbup Took it for a spin and motor feels good :thumbup Looked at fork seal and it's leaking :thumbdown Bugger. need to order seals, so is the front end definitely 5pw r1 (2002 - 2003) Re: New gen 1 has 7000rpm fault code......................... - Exupnut - 23-10-15 Good to hear :-)........gonna do mine tomorrow.....minus the Tyskie....and the heat lol Re: New gen 1 has 7000rpm fault code......................... - unfazed - 23-10-15 Never heard of the 7000K fault code from slack cables :rolleyes Re: New gen 1 has 7000rpm fault code......................... - nickodemon - 23-10-15 They were also routed wrong and the valve was positioned slightly out. I will check again tomorrow, as it seems to do it if the bike has been lying a while as it stops doing it when the bike has warmed up Re: New gen 1 has 7000rpm fault code......................... - sadlonelygit - 24-10-15 4xv-5jj 41mm 5pw 43mm iirc get the very nears out! Re: New gen 1 has 7000rpm fault code......................... - nickodemon - 24-10-15 Just taken the bike for a 30 mile ride in the wet. It doesn't like white lines! It also doesn't seem to want to lean over as much as the standard fazer? I thought it would because of the r1 front and r6 rear. It definitely doesnt handle anything like my fazer with the 2008 r1 front/r6 shock. I think the chain is too tight so going to loosen it off a bit and see if that has affected the handling. Fork seal has stopped leaking. Just bought a set of seals as well :'( Re: New gen 1 has 7000rpm fault code......................... - nickodemon - 24-10-15 (24-10-15, 01:51 PM)sadlonelygit link Wrote: 4xv-5jj 41mm They are 43mm I now have a set of fork seals that will sit on the shelf until such time as i need them I have been out again and the fork is still not leaking, so i think either i have been spraying wd 40 or gel cleaner and it has got on the stanchion :groan
