A question regarding clutch - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: A question regarding clutch (/showthread.php?tid=74113) |
A question regarding clutch - igor5b - 20-10-15 Greetings to fellow Fazer riders, I hope you all are having a pleasant autumn rides ![]() a question: my clutch leaver has a lot of travel up and down in relation to the handle bars. Is that normal, is everyone's clutch lever like that? thanks in advance for your help, and sorry if this has been asked before. Re: A question regarding clutch - slappy - 20-10-15 Do you mean it wobbles up and down in the perch? If so the through bolt could be worn or if it has a bush where the bolt goes through that could be worn. Or they both could be worn
Re: A question regarding clutch - igor5b - 20-10-15 thanks for your reply Yes thats what I meant. so im guessing this is not normal, looks like ill be shopping for a new bolt. its not really a problem, but its abit annoying Re: A question regarding clutch - darrsi - 21-10-15 Looking at pictures it doesn't look like these ones have a bush in them, i doubt it'll be the bolt that'sworn, but more than likely the actual lever. On my last bike you could tap the bush out and put it back in upside down and double the life of it. They're only a few quid, i'd start with a new lever first. Re: A question regarding clutch - igor5b - 22-10-15 Thanks for your advise, ill try the leaver option and see what happens
