Parts needed - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Parts needed (/showthread.php?tid=74099) |
Parts needed - zer0n - 19-10-15 Hi, Looking for some replacement parts for a FZS600 2000.
Cheers z Re: Parts needed - RMT1983 - 19-10-15 PM me mate Re: Parts needed - Bretty - 19-10-15 I'm in Northwest London. I have a rocker cover, no bolts or seals. I'm not sure about end plates, or gasket. Re: Parts needed - zer0n - 19-10-15 (19-10-15, 11:30 PM)Bretty link Wrote: I'm in Northwest London. I have a rocker cover, no bolts or seals. I'm not sure about end plates, or gasket.Hi there, Thanks for the reply but I need the bolts and seal as well. Replacing these separately will cost twice as much as the cover from what I've seen. Re: Parts needed - Bretty - 20-10-15 Tell a lie... :rolleyes What you see is what you get. Take it or leave it. ![]() Re: Parts needed - Bretty - 20-10-15 Picture 2 Re: Parts needed - zer0n - 20-10-15 (20-10-15, 12:41 PM)Bretty link Wrote: Tell a lie... :rolleyes What you see is what you get. Take it or leave it. Hey Bretty, That's good. Has the seal and caps. If I could source some cheap bolts (can probably salvage 3 or 4) then I'd take it but atm all I have found are a pack for £60. ;[ Will continue searching and let you know. Cheers z Re: Parts needed - Bretty - 20-10-15 You might have a bit more luck in your search if you look for 'cam' cover rather than 'rocker'.
Re: Parts needed - slappy - 20-10-15 Take one of the bolts to a local engineering supplier or nut and bolt supplier, you might be able to get a matching bolt and if it is like my local supplier they will happily just sell you the amount you actually need. Re: Parts needed - zer0n - 20-10-15 Thanks for the hints peeps. Will try that tomoz Re: Parts needed - zer0n - 22-10-15 [size=1em]All sorted, I hope.[/size] [size=1em]Cheers peeps x[/size] |
