90 degree countersink bit wanted - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: 90 degree countersink bit wanted (/showthread.php?tid=74077) |
90 degree countersink bit wanted - joebloggs - 16-10-15 As it says, want one for both alloy and steel, not going to be used often and ones online seem a little expensive just to leave in the bottom of the tool box. :eek Anyone brought a cheapie and was it any good? Re: 90 degree countersink bit wanted - Frosties - 16-10-15 How big does the countersink have to be Joe. No joy if you used the biggest steel drill bit that'll fit in the chuck? Re: 90 degree countersink bit wanted - celticdog - 16-10-15 I've only got a 82 degree countersink. Re: 90 degree countersink bit wanted - joebloggs - 16-10-15 Hole is 9mm but countersinking a m8 which is about 16.5 diameter. Don't want to use large drill bit as want accurate hole (ocd) may ask engineering at work but have feeling they'd probly use a drill bit as finish not a priority to them Re: 90 degree countersink bit wanted - chris.biker - 16-10-15 You can sharpen a normal drill to do the job. Re: 90 degree countersink bit wanted - Rob R - 16-10-15 https://www.machinemart.co.uk/shop/product/details/cht530-6pce-hss-countersink-set?da=1&TC=SLI-060235530 not sure that they're 90 degrees though. Rob Re: 90 degree countersink bit wanted - joebloggs - 16-10-15 (16-10-15, 08:37 PM)Rob R link Wrote: https://www.machinemart.co.uk/shop/product/details/cht530-6pce-hss-countersink-set?da=1&TC=SLI-060235530 Thanks, only thing is I don't want to invest £20 + on tools I'd rarely use again Re: 90 degree countersink bit wanted - YamFazFan - 25-10-15 Car boot sales are an absolute goldmine for tools. If you are prepared to spend a few minutes sorting through boxes you can find some real gems at bargain basement prices .Saw loads of countersinks at the local one this morning. Even the second-hand tool dealers who have all the best stuff are a fraction of the cost of buying new. I rarely buy any tools from the shops any more. |
