06 fazer 1000 fault code 20 - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: Introduction (https://foc-u.co.uk/mybb/forumdisplay.php?fid=68) +--- Thread: 06 fazer 1000 fault code 20 (/showthread.php?tid=73961) |
06 fazer 1000 fault code 20 - duffy - 02-10-15 hi, everybody, couldnt post on the intro board for some reason. ive had my o6 fazer 1000 since 07 and love it to bits.however its getting difficult to start wont idle and is showing an error code of 20.any suggestions would be welcome. Re: 06 fazer 1000 fault code 20 - slappy - 02-10-15 Think error code 20 is air intake sensor fault, there is one top of the air filter housing. Unplug it and clean it , check for any loose wires and corrosion, see if that clears the fault. I assume you have the gen2 fuel injected fazer, not gen1 the carb version. Re: 06 fazer 1000 fault code 20 - Val - 05-10-15 (02-10-15, 01:59 PM)slappy link Wrote:Think error code 20 is air intake sensor fault, there is one top of the air filter housing. Unplug it and clean it , check for any loose wires and corrosion, see if that clears the fault. :agree Two sensors can give code 20 - Good idea to download service manual from download section here: http://foc-u.co.uk/index.php?action=downloads;sa=view;down=12 Re: 06 fazer 1000 fault code 20 - duffy - 09-10-15 Thanks for the info ! Pete |
